Old 04-28-2003, 05:06 PM   #1
doublest's Avatar
Send a message via MSN to doublest
Camber Help?
Hi how should the camber be set on the front and back wheels. After building my MR4 my front wheels are facing inwards and front wheels are sitting straight.
Please help in what the different settings do and what u reccomend.
doublest is offline   Reply With Quote
Old 04-28-2003, 05:15 PM   #2
fatdoggy's Avatar
R/C Tech Charter Subscriber
Start around 1 to 1.5 degrees of camber and then work for even tyre wear. The wheels facing inwards is called toe-in, it increase stability at high speed.
Cheers.
fatdoggy is offline   Reply With Quote
Old 04-28-2003, 05:28 PM   #3
doublest's Avatar
are there any camber and toe-in setup guides on the net.
Ive PM'd you fatdoggy.
Old 04-28-2003, 08:48 PM   #4
fatdoggy's Avatar
doublest - You've got pm. I jotted down the basics for you.
Old 04-29-2003, 03:59 PM   #5
doublest,
The Xray site has an excelent setup guide that explains camber, castor, toe-in, etc...
http://www.teamxray.com/teamxray/pro...&kategoria=253
If you can't afford a setup station like from Hudy or Integy, RPM offers some inexpensive camber and toe-in gauges. Of course, you can always try to eyeball it....
-Headbanger
Headbanger is offline   Reply With Quote
Old 04-30-2003, 11:53 AM   #6
Doublest,
you NEED to visit This Site
you should find alomost everything you need there
Mort is offline   Reply With Quote
Old 05-03-2003, 06:33 AM   #7
Cole Trickle's Avatar
Setup guide
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Camber out / Elevated Camber ronestar Nitro On-Road 0 07-27-2006 07:24 AM
how to set my camber to zero aquito Electric On-Road 4 05-03-2006 11:00 PM
camber? peahbeez Electric Off-Road 4 06-02-2005 03:26 PM
how to set camber ? Blaze1 Rookie Zone 5 05-04-2004 06:37 AM
camber wahturi Nitro On-Road 2 12-20-2002 04:17 PM
