Old 04-28-2003, 04:22 PM   #1
doublest's Avatar
Send a message via MSN to doublest
Default My Gearing?!?
Hi i have the standard Gearing on my MR4-TC which is 22T pinion and 78T Spur. Which i been told that for a 27 Turn stock a good starting point would be a 30T pinion and 75T Spur.
I will be using a Monster Horsepower Stock and im racing on quite a twisty track, with a couple of quite fast straights.
What do u reckon on this?
doublest is offline   Reply With Quote
Old 04-28-2003, 04:33 PM   #2
CGR
CGR's Avatar
30/75 seems real high for a monster. I set my monster up with a 7.5 final drive (tc3) and 30/75 in the yok would be a 5.5 I believe
CGR is offline   Reply With Quote
Old 04-28-2003, 04:49 PM   #3
doublest's Avatar
Ok with my 22/78 my overal drive ratio is 7.8 and rollout is 22.56, is this overgeard or undergeard for a twisty track witha couple of quick straights.
Old 04-28-2003, 06:08 PM   #4
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I personally gear around 8.2-8.5, the monster makes a lot of revs so i gear very short and still have plenty of straight speed.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 04-28-2003, 06:10 PM   #5
CGR
CGR's Avatar
7.8 is probably about right or maybe a gear it an RCH lower. Mine is just a tiny bit too high right now.
Old 04-28-2003, 06:11 PM   #6
Moderator
It all depends on the track size as well
SMC Racing
Old 04-28-2003, 06:14 PM   #7
Moderator
I saw your picture on the other post you made, that track is very big. Id gear around a 7.5 to 7.8
SMC Racing
Old 04-28-2003, 06:18 PM   #8
sup
sup's Avatar
will that ratio apply to most stock motors? will be running a green machine 3 and have no idea yet as to what pinion gear to get?.. any suggestions as to ratio and what pinion to get? ..will be running a tight track. thanks!
sup is offline   Reply With Quote
Old 04-29-2003, 05:01 AM   #9
sosidge's Avatar
Around 7.5:1 is a safe starting point for most stocks on a tight track.
Gearing lickashotblaow Electric On-Road 0 07-29-2007 05:47 PM
NeeD Help with gearing please daver1 Electric On-Road 4 07-20-2007 09:12 AM
Gearing for TT-01 tl-01-jhb Rookie Zone 0 11-10-2004 05:35 AM
Need help gearing a TC3 fasda1 Electric On-Road 10 11-06-2004 11:51 AM
Gearing??? mike m Monster Trucks 3 01-24-2004 07:54 PM
