specs for novak t-4
Old 04-28-2003, 01:42 PM
traxxasdude's Avatar
Default specs for novak t-4
I found out htat I have a t-4 esc and I am currently using it in my car. I cannot find specs for it because it was discontinued it 1994.
traxxasdude is offline
Old 04-28-2003, 04:39 PM
cmk
... junk ...
The T4 was Novak's low end model back in the day ... before high frequency drives, regenerative braking, and true adjustability.
Your best option is to yank it, have it bronzed for posterity, and fork out $100 for a newer model.
Today's high frequency ESC's are leaps and bounds better than the T4's.
cm "had one ... back in the day" k
cmk is offline
Old 04-29-2003, 01:36 PM
so are you saying that I could sell it for $100? The person who owned it before me cut off the current limeter, will that lower what it is worth?
Old 04-29-2003, 02:16 PM
cmk
LMAO
Dude ... it's not worth $1, let alone $100.
cmk
cmk is offline
Old 04-29-2003, 02:41 PM
oh, will it even WORK with a 10t mod?
Old 04-29-2003, 06:12 PM
cmk
I doubt the T4's were rated for mods as low as 10T's. I'm sure it will work ... but who knows how long.
cmk
cmk is offline
Old 04-29-2003, 07:04 PM
pkranger63's Avatar
http://www.theshreves.com/rc_stuff/manuals/novak_t4/
it should have some info you can use.
pkranger63 is offline
Old 04-29-2003, 08:26 PM
cmk
Someone had entirely too much time on their hands.
cmk
cmk is offline
Old 04-30-2003, 02:07 PM
what will happen if I don't install the capacitors?
Old 05-01-2003, 01:47 PM
that esc wouldnt be very good for racing, but its not junk. If you're just bombing around with something it would be great because they are durable.. I raced them when they first came out. I would say it is better than most economical escs as far as durability goes, but would not use it for racing.
Shouldnt have any probs running a 10turn.
synapse79 is offline
Old 05-01-2003, 01:50 PM
that capacitors are installed to filter out high frequencies from the more and esc so they do not interfere with the receiver. They also help to keep the motor from arking. You should atleast install one from + to -
Old 05-01-2003, 04:37 PM
I just tried it out it works for about 5 sec, but than my tl pinion stops meshing with the spur. Still waiting for shippment (day 9)
Old 05-03-2003, 05:23 AM
pkranger63 - that link was very helpful, and i noticed that on the picture labled "back factory packaging" than it says it will handle the best mods.
