Old 07-11-2007, 06:55 PM   #1
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default RUBBER TIRE LIFE ASPHALT VS CARPET
SORRY I DID A SEARCH BUT COULD NOT FIND ANY INFO.
LETS JUST US 19 TURN FOR EXAMPLE. JUST BECAUSE IT'S IN THE MIDDLE.
AFTER HOW MANY RUNS WILL YOUR LAP TIMES START TO SUFFER ON RUBBER TIRES ON ASPHALT?
ALSO HOW MANY TENTHS DO YOU LOOSE?
AFTER HOW MANY RUNS WILL YOUR LAP TIMES START TO SUFFER ON RUBBER TIRES ON CARPET?
THANKS.......
RED-LINE M03 is offline   Reply With Quote
Old 07-11-2007, 07:42 PM   #2
Every track will be different in that respect. Also the compound of rubber you use will have an effect on that as well.
Old 07-11-2007, 08:39 PM   #3
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
1 to 2, depending on tire and the abrasiveness of the track.
Anywhere from 2-5 tenths per lap, also depending on tire and the abrasiveness and amount of wear.
Usually after the 3rd run they slow down to a point where it is pretty noticeable. The 1st and 2nd runs are very good, 3rd is just slightly slower but not much at all.
Depending on the tire, about 2-3 tenths slower after the 4th or 5th run...and generally they stay that way for a few more runs.
THANKS.......
See bold
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 07-11-2007, 08:49 PM   #4
Little_Mike's Avatar
replace your tires if your car is driving erradically (just to make sure) and replace if they begin to develop a bit of a "ridge" on the sides.
Little_Mike is offline   Reply With Quote
Old 07-12-2007, 08:33 AM   #5
swopemike's Avatar
THANKS.......
Search "Rubber Tires for Dummies" that thread has all the info you listed. Brian's response addressed it, but there's lot of good info here
http://www.rctech.net/forum/showthre...res+Dummies%22
swopemike is offline   Reply With Quote
Old 07-12-2007, 11:48 AM   #6
Thanks bro.........Thats exactly what I was looking 4.
Life expectancy of rubber tires on carpet? artwork Electric On-Road 9 07-30-2008 11:15 AM
Rubber tire life? CREWMAN Electric On-Road 23 04-10-2008 02:05 AM
Xray T2'007 EU Rubber Tire Asphalt yyhayyim R/C Items: For Sale/Trade 3 04-27-2007 10:49 AM
What's a tire truer? And who makes good rubber tires for asphalt? Prozak Rookie Zone 3 10-15-2006 01:53 AM
Practices to extend the competative life of a rubber tire on carpet BlackKat Electric On-Road 10 08-18-2005 03:26 PM
