Gearing 27T Stock
Im switching from mod to stock 27 Tourers and have limited practice
before race night , running a MR4tc 2.2 final gearing and looking for a starting point.
Thanks Mark
Thanks Mark
what motor will you be running? what is the track like? long & fast? Tight and Technical?
i run a Trinity CO27 and gear it in the region of about 6.4
Hey guys, I run at a track that is 100X40 roughly. It uses the whole 100 ft for the back straight, and the infield is very tight. Im running an Monster Stock on my T2 007. 114/29 is my gearings with a finial of 6.95 with 57mm foams. After freezing the motor it still comes off at 180 which is too hot. Am I still undergeared?
I was running a 118/31 and it didnt get too hot, which is a rollout of 6.73 I belive. I switched becuase I didnt have anything off the corner.
What rollout should I be running on this big track.
It's difficult to judge, but what is the final internal gearing ratio on the T2?
Tyler for there run rear roll centers up high.. Diff in middle purple rear springs and magents fronts.. try double pink rears ,double pink orange fronts 30wt X ray oil 2 hole pistions.. 1 deg rear toe..1 deg rear camber 1 1/2 deg front camber.. 4 1/2 mm RH.. 1 mm front droop 2 mm rear droop.. That is a start
Thanks Everyone , I will be racing mainly on a technical track and have various motors,P2k2, CO27, Hellfire,Epic Quad,Orion Core . Probably will use the Hellfire as most guys are using one but it will come down to the stopwatch I guess.
