Old 04-27-2003, 07:20 PM   #1
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
Default Comments on GM SX9
GM SX9
Any comments.. I saw one this weekend and it is soooo small !. Is this the speedo to have for 12th scale ?
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 04-28-2003, 12:23 AM   #2
Cole Trickle's Avatar
As far as I know, GM speedos in general are good, but complicated to adjust. There are several other micro ESC's to choose from. What about this:
Specification:
Voltage Input: 4-8 cells
On-Resistance: <0,001 Ohm
Recommended motor: > 9 Turns
B.E.C. Output Voltage: 6.0 V
B.E.C. Impulse current: 3.0 A
B.E.C. Constant current: 1.0 A
Case Size: 33x23x16mm
Weight: 22 g
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-28-2003, 09:14 AM   #3
dw
They aren't that bad to adjust.
The main problem is the badly translated instructions.
dw is offline   Reply With Quote
Old 04-28-2003, 09:17 AM   #4
Barry White's Avatar
Never seen one but it is 1/12 world champion...
Barry White is offline   Reply With Quote
Old 04-28-2003, 09:19 AM   #5
wa?
my spirit + speedo was xecellent, its really small and easy to adjust, the instructions are easy to understand, and the bec on it can cope with 4 cells, as i ran it in my 12th last season, but i dont know how to wire my reciever pack to it, as it dosnt have a switch. anyone have an idea?
rice98w is offline   Reply With Quote
Old 04-28-2003, 09:27 AM   #6
shrekair's Avatar
Trader Rating: 9 (91%+)
novak sells replacement switches for like $4.50 or something that you can easily wire in.
shrekair is offline   Reply With Quote
Old 04-28-2003, 02:40 PM   #7
Originally posted by rice98w
wa?
From the manual
Turn the speed control on/off:
The speed control can be turned on using either the setup button (default setting) or automatically by connecting the speed control to a battery. This function can be set in the setup mode ”function”.
To turn off the speed control press the setup button for five seconds or push the throttle to the full-break position for five seconds. The latter function can be switched off.
There's also an optional external switch.
Old 04-29-2003, 05:06 AM   #8
sosidge's Avatar
SX9 - VERY small and lightweight (makes a quantum look big!).
A friend has one - blew up the first one (had a problem with the cap and then it went), also found that the solder points were so small it was hard to get an iron any where near the wire without melting the case. Programming seems identical to the V12 (same instruction manual)
Old 04-29-2003, 09:06 AM   #9
rayhuang's Avatar
My SX9 just arrived and it is SOOO small. And yes it does make a Quantum look huge!!
I bought it so I could put it in my 12th scale, re-arrange all my elecronics and get the Personal Transponder and a receiver pack in there. COuldnt fit that stuff in neatly with the Cyclone!!!!!-Though I LOVE NOvak stuff. Just wish they'd make a micro ESC soon.
comments on futaba streetstock Electric On-Road 11 06-26-2005 08:23 AM
Comments on Keyence ESC nnick Electric On-Road 15 09-14-2004 01:48 PM
Ofna LD3 Pro-Any comments? macnkitty2002 Nitro On-Road 5 07-19-2004 12:14 PM
Comments!!!!!! nitrous555 Electric Off-Road 3 01-20-2004 07:22 PM
