Lipo-how do you know when..... >
Old 07-08-2007, 06:21 PM
  #16
and if your just to lazy to look
http://www.rcgroups.com/forums/showthread.php?p=1199486
http://www.rcgroups.com/forums/showt...hreadid=139208
TAMIYAMANUK is offline
Old 07-08-2007, 06:23 PM
  #17
kuzo's Avatar
Hmmm...so the charger is stopping at what it says is 8.4V but the multimeter is coming in lower? So one of them has to be wrong then as long as you are checking with the multimeter right after taking it off the charger. Got a spare charger or a friend's you could test with?
kuzo is offline
Old 07-08-2007, 06:26 PM
  #18
Sime's Avatar
Its charging now, as soon as it comes off charge, ill check it with the multimeter.
Buy the way, I havnt over discharged this battery, i was wondering what the symtoms are in case i ever do.
Sime is offline
Old 07-08-2007, 06:28 PM
  #19
Sime's Avatar
OK, straight off charge:
Surpernova 8.42
Muti meter: 8.34
Through Balance port: Both are reading 4.17 with multimeter
Sime is offline
Old 07-08-2007, 06:30 PM
  #20
kuzo's Avatar
Oh not too lazy, I've seen plenty. I do believe we are talking about Orion lipos at the moment and I guess you're too lazy to differentiate between the large array of pack types available. Educate yourself on the differences before you spout off the same crap all lipo fear spreaders use. I bet if you saw a pack fire from a moron who wired a bunch of cell phone lipos together and ran in a car with a 8 turn brushed the results would scare you too. But that has nothing to do with this discussion either.
Can you find picture/video/stories about Orion packs having this same scary problem? I'd like to see you try...
kuzo is offline
Old 07-08-2007, 07:00 PM
  #21
GymBeam's Avatar
Originally Posted by Sime
Yes it does have CC/CV and my charger says 8.4 but my mutimeter says 8.32, so who is telling the truth.........? And I do run till completion.
thats because every charger is calibrated differently.
one charger may read 8.4v another 8.35 another 8.45...
obviosly with regards to lipo, if your charger reads a higher voltage than what it actually is, then its a good thing (in terms of safety and longevity of the lipo) because it will slightly undercharge the lipo to 8.32v
what happens when a charger actually charges at a ccv at 8.45v? could be a safety risk
GymBeam is offline
Old 07-08-2007, 07:32 PM
  #22
Sime's Avatar
I'll have to get my Mutimeter tested against a calibrated MM to see how far out it is and go from there.
So, its safe to say, that if I charge my Lipo and its only getting a voltage of say 8.0v, I should worry?
Sime is offline
Old 07-08-2007, 08:05 PM
  #23
GymBeam's Avatar
it will be under-charge
GymBeam is offline
Old 07-08-2007, 08:12 PM
  #24
Sime's Avatar
OK, I need a bit more info.
So with Lipos, you cant fully discharge it, so when it comes to charging, your charger will say for example 3500mah was put in during that particular charge, so how do you know for sure that your Lipo is capable of its full 4800mah? if at 4800mah, you lipo should read 8.4 volts, so say that if your Lipo is fully charge now at say 4000mah, the voltage will read lower.
So in a round about way, 8.4v will only be read at a fully charged 4800mah?
Sime is offline
Old 07-08-2007, 08:35 PM
  #25
adamge's Avatar
Sime, to see the full capacity put back in the by the charger you need to discharge the lipo completely. To do that, you need to discharge it at 4.8A, and cutoff the discharge at about 3.5V. It'll probably cost you some cycle life, though.
adamge is offline
Old 07-08-2007, 08:38 PM
  #26
Sime's Avatar
Bugger hey, Ill give that a miss I think. They cost $300 here in Australia.........
Sime is offline
Old 07-08-2007, 09:13 PM
  #27
andrewdoherty's Avatar
Trader Rating: 49 (100%+)
Those are from 2003 . . .4 years ago . . and they're not orion cells.
andrewdoherty is offline
Old 07-08-2007, 09:42 PM
  #28
UN4RACING's Avatar
Trader Rating: 22 (100%+)
chart 1
This link has a chart that shows a 7.4 will peak at 8.4 volts and test after the charge any where from 8.32 volts to 8.44. I assume thats why there rated nominal. Each pack can be a little better than the next.
Chart 2
I think is the burst that each cell can handle not sure though.
Accessing this site it wont load for me on some links.
http://lib.store.yahoo.net/lib/toytr...iPo-Safety.pdf
Good stuff.
UN4RACING is offline
Old 07-08-2007, 09:51 PM
  #29
UN4RACING's Avatar
Check the percent of charge or (charge capacity setting) I have my Ice set at 110. Orion recommends 90%
If your set at 80 that may be the reason for the voltage readings.?
Old 07-08-2007, 11:38 PM
  #30
Sime's Avatar
Mines set at 100%
Sime is offline
