Old 07-08-2007, 02:59 PM   #76
Oh yes I curious what bodies are we going to try and use?Also a 13.5 with Lipos- on our State series???I've still got my narrow HPI(Mercedes) bodied Normal Bolink car I designed ready to go.As for wide bodies I've still got some new Bolink wide GTP bodies available (Nissan GTP and the old TOJ).I'm sure the people with all the old Bodlink molds could make more.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 07-08-2007, 03:24 PM   #77
tallyrc's Avatar
for 200mm you could run McAllister "ravens" sort of a hybrid lmp/gtp/coupe... unless you just wanted to run nitro sedan bodies..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 07-08-2007, 03:25 PM   #78
volracer's Avatar
Send a message via ICQ to volracer
TOJs; howabout Sckhees?
volracer is offline   Reply With Quote
Old 07-08-2007, 04:57 PM   #79
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Originally Posted by AdrianM View Post
As a design exercise BMI Racing designed a new 1/10th pan car, the DB10R. It is designed to be 200mm wide so all 200mm nitro bodies fit it (Lola, Sedan, LeMans, HPI Vintage Muscle Car...anything that is 200mm wide fits)
It is also set up to to run LiPo and BL motors out of the box. I am thinking this car would be a hoot with a Orion 4800 Lipo or Core Racing 5000 LiPo and a 13.5T BL motor. With that motor it should be as fast as a mod sedan.
It uses a normal AE front end, and commonly available IRS oval axles and hubs.
Right now its just a CAD file. Let me know if you have some interest in this and I will pass it on to Jason.
Adrian...get to work on those cars quick...and make them metric so Eu fans can buy them up, too. It'll be a hit...we'd love to race them down here in South Florida, too...but, need the support of a good company.
yyhayyim is offline   Reply With Quote
Old 07-08-2007, 05:21 PM   #80
AdrianM's Avatar
Bodies are all up to you guys. We just figured make it 200mm so you could fit a huge array of currently, commonly available bodies.
Check some of these out (200mm HPI bodies): http://www.hpiracing.com/bodies/body-tcw.php
Old 07-08-2007, 07:43 PM   #81
rcgen's Avatar
Add one more to that list....I'd like to run the 1/10 pan cars again....
rcgen is offline   Reply With Quote
Old 07-08-2007, 08:42 PM   #82
Headshot's Avatar
Send a message via Yahoo to Headshot
Yohan, is this something I should look into? After I build my Porsche Cup of course.....
Frank
"Some People are like a Slinky- basically useless, but still bring a smile to your face when you push them down a flight of stairs"
Headshot is offline   Reply With Quote
Old 07-10-2007, 01:41 PM   #83
gijoe64's Avatar
Trader Rating: 30 (100%+)
Is the new Darkside car 200mm? And I just perchaced the protoform P35 bodies at my local hobbyshop for 10.00 a piece.
gijoe64 is offline   Reply With Quote
Old 07-10-2007, 01:55 PM   #84
tallyrc's Avatar
the darkside car goes down to190mm, 200mm, and up to 225 in the rear. it is also a "down the middle" battery configuration with center pivot and links.. lipo ready..
Old 07-10-2007, 02:51 PM   #85
gijoe64's Avatar
Here is a question what type of battery configuration would you guys perfer 4cell or Lipo? What are the advantages and disadvantages? Would Lipo be to much for indoor carpet?
Old 07-10-2007, 03:02 PM   #86
yyhayyim's Avatar
Franky...this is something you will defenitely love. They are simple, but man are they fun to drive. They will outperform TC's in any class, nitro or electric, and the cost of running them is much less.
Old 07-10-2007, 03:07 PM   #87
SWTour's Avatar
Not if coupled with the right motor combination...
SWTour is offline   Reply With Quote
Old 07-10-2007, 05:02 PM   #88
AdrianM's Avatar
Well...since some are thinking 4 cell 27T is too fast for some smaller carpet tracks what do you suggest....540 can motors?
7.4v Lipo with a 27T or 13.5BL will be faster than Sedan Mod lap time wise...its was the last time I ran it a few years ago.
I think running 4 cell might be the way to go. You can run normal motors like 13.5, 10.5 and 5.5 BL to get normal ranges of speed from novice to expert level drivers.
Old 07-10-2007, 05:07 PM   #89
tallyrc's Avatar
i'd be curious to see what 6 cells and those new 17.5 or 18.5 motors would be like.. just out of curiosity.. but 4 cell 10.5 or faster could be a lot of fun.. and cheap!
Old 07-10-2007, 05:46 PM   #90
AdrianM's Avatar
There is a side benifit to 4 cells...
If you have a 1/12th car all you need to convert to 1/10th is a new rear axle setup, new front lower chassis and 1/10th tires.
10th scale pan cars? DennisNyholm Electric On-Road 38 03-16-2006 12:55 AM
new to 1/10th scale electric cars topgun100 Rookie Zone 2 01-30-2005 05:29 AM
first time user of 1/10th scale electric car topgun100 Electric On-Road 1 01-06-2005 11:54 AM
1/10th scale 2WD touring cars mushu Electric On-Road 12 05-05-2003 10:23 AM
