Old 09-07-2007, 02:10 AM   #31
rampal's Avatar
Send a message via MSN to rampal
Originally Posted by alan1467 View Post
Hope they have sorted the problem with the weak cases on the receivers. I have two broken ones now
how did you broke them?? taking them off the chassis and the case not resisting the servo tape?? crash?
thanks!
The Blue Armada: Tamiya TRF415MSXX, Tamiya TA05MS, Tamiya/Xenon TA05
Novak Brushless, Orion/Peak LiPo batteries, 5-cell
Sanwa M11 DSSS, KO Propo Servos
rampal is offline   Reply With Quote
Old 09-07-2007, 02:31 AM   #32
alan1467's Avatar
Well the first one was when I removed a servo lead. It was tight and the top of the case came off breaking the small lugs that hold it together. The second was in off road and again the small lugs broke off during the race splitting the case. It appears to be a common fault with the 2.4 caes but noone has had problems with the RX431 cases which are the same, so it may have been a bad batch of cases for the 2.4 ones. There is another thread in Nitro onroad saying that.
Tamiya TRF - Tekin
F104W Pro - CRC Gen X10
alan1467 is offline   Reply With Quote
Old 09-07-2007, 02:55 AM   #33
RC MARKET's Avatar
Sanwa after will release case for sale
Sanwa/Airtronics DSSS-sa-107a40551a.jpg
RC MARKET is offline   Reply With Quote
Old 09-12-2007, 05:21 PM   #34
minicooper's Avatar
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
Send a message via AIM to minicooper Send a message via Yahoo to minicooper
Originally Posted by minicooper View Post
I've had the unit for awhile now, two weekends ago I was at Tamiya's Track and experienced some glitching. It was sort of hesitating with the inputs from the radio. It was also crawling forward when I would turn the steering wheel on the radio. Have not had a chance to run the car since then but I will this weekend. I am going to rebind the transmitter and receiver again and go over the radio settings as well. If I continue to have glitching, I'll let you guys know and will contact Airtronics. BTW, I'm using an M8.
All good no glitching
minicooper is offline   Reply With Quote
Old 09-13-2007, 02:46 PM   #35
rampal's Avatar
good to know, as mine is on the mail right now... If i like it and it is reliable, I will be soon changing all my spektrum stuff for this...
Old 10-05-2007, 04:23 PM   #36
rampal's Avatar
Hey, Just realise that on the sanwa japan site there is the new 2.4GHz module for the M11/Exzes Plus.... but instead being TM-221DS and RX442DS (receiver) the numbers are TM-222DS and RX442DS..... what is the difference???
Old 10-05-2007, 09:00 PM   #37
I am trying to set these recievers up, does it require 3 hands to do? I have spent over an hour trying to bind these recievers
DAVE BERNATH is offline   Reply With Quote
Old 10-16-2007, 03:20 AM   #38
rampal's Avatar
bump for moving to the new radio and electronics thread.
Anyway, does anyone know about the difference between the modules 221 and 222 and the receivers 441 and 442?? Is it only a market division? Is there new software?
Old 10-16-2007, 07:14 AM   #39
Eirik's Avatar
Has anyone tried to move the antenna from the module to the original antenna position on the radio?
I have heard of people getting glitching problems after doing this, is this true?
Thanks!
Eirik is offline   Reply With Quote
Old 10-16-2007, 07:29 AM   #40
RC MARKET's Avatar
Thanks!
yes HK many peoples was moved antenna to original position .
Old 10-16-2007, 01:01 PM   #41
Eirik's Avatar
And there has been no issues reported?
Will you get spare antennas in stock anytime soon?
Thanks,
Eirik
Old 10-16-2007, 01:04 PM   #42
rampal's Avatar
Thanks,
Eirik
at least on the US I've heard that if you do the mod you 'void' the FCC compliance and they can bar you on using the radio... Don't know if that is true with CE.....
Old 10-16-2007, 01:42 PM   #43
Ed Anderson's Avatar
Trader Rating: 26 (100%+)
I've been trying to find this out for a while.....Like to see it done.
http://www.rctech.net/forum/showthread.php?t=173092
Ed Anderson is offline   Reply With Quote
Airtronics M11 DSSS 2.4 Ghz Cheap! Sean R R/C Items: For Sale/Trade 4 06-22-2008 10:23 AM
WTB AIRTRONICS DSSS RECIEVER qcstrokr R/C Items: Wanted to Buy 1 06-13-2008 01:19 PM
Airtronics / Sanwa M11 2.4ghz DSSS chokudori Radio and Electronics 3 05-15-2008 03:56 PM
Airtronics/Sanwa DSSS 2.4Ghz Problem ruicortez Nitro On-Road 2 03-11-2008 07:41 PM
M11 WITH LI[PO IN TRANSMITTER AND AIRTRONICS DSSS SYSTEM twistedone R/C Items: For Sale/Trade 14 10-18-2007 03:50 PM
