Old 04-27-2003, 07:16 AM   #16
jedi's Avatar
Default Hey Steevo!
What gearing are you using for the monster stock in your evo? And how big a track do you run on? How long is your staight?
jedi is offline   Reply With Quote
Old 04-27-2003, 11:02 AM   #17
Suspended
Do you gear the monster stock kind of like you would gear the green machine 3 pro?
R C king is offline   Reply With Quote
Old 04-27-2003, 01:41 PM   #18
Steevo's Avatar
Default Re: Hey Steevo!
Hi Jedi,
Its a fairly fast flowing track for the best part with a long back straight. It has a Variable layout... I use 88T Spur and 34T-36T Pinion Mostly..
Steevo
Steevo is offline   Reply With Quote
Old 04-27-2003, 06:05 PM   #19
Registered User
Calvin Ng's Avatar
Send a message via ICQ to Calvin Ng
is that 64 pitch?????
how bout the dyno tuned core. is that any good.
im planning to get a stock too and our track has a long straight to. it not very tight but alot of turns?
what do you recommend
im using a p2k right now and im using a 81 spur and 30 pinon? should i make any changes to my gearing?
Calvin Ng is offline   Reply With Quote
Old 04-27-2003, 06:19 PM   #20
Registered User
Calvin Ng's Avatar
Old 04-27-2003, 08:15 PM   #21
jedi's Avatar
Default Thanks Steevo!
Wil give it a try. I could not get the monstre stock to run weel at all. Using an evo 3 in a large outdoor track with a 150 foot straight.
Old 04-27-2003, 08:23 PM   #22
Steevo's Avatar
Hi Calvin,
Using original Tamiya 0.4 Module (metric 64Pitch).
Unfortunately I have no experience with the Orion Core so it would not be appropriate for me to comment.
If your track is a fairly high speed track then try the Monster Stock.
I don't know which chassis you are running so I am not sure if your gearing with the P2K is right or not. Let us know what you are running.
Steevo
Old 04-27-2003, 08:26 PM   #23
Steevo's Avatar
Default Re: Thanks Steevo!
jedi,
Try the 88Tooth Spur with a 34 or 36 Tooth Pinion. Depending on what the twisty bits are like..
Steevo
Old 04-27-2003, 09:33 PM   #24
Registered User
Calvin Ng's Avatar
im running a trf414mII its about the same as a losi i guess or better.
does the motor get hot???
so the monster is the same as a 13 turn which one????
this might be a stupid question but when you guyz say p2k 2 are you saying p2k 2 pro????
Old 04-27-2003, 09:54 PM   #25
Steevo's Avatar
Calvin start with a rollout of about 34 to 35mm on your 414 when using the monster.
As far as being as fast as a 13 Turn well let me put it into perspective a bit better. My brother was running his TA04R which is a little heavier than my TB EvoII. He is using a Team Orion Chrome Modified motor which is quite well maintained and geared well. My Evo II with Monster Stock Pro was matching him almost inch for inch all around the track and kept up with him in the long straight. My monster was probably looking for another tooth or two on the pinion as it was quite hot at the end of the run.
But certainly in this situation the monster was an even match.
In all honesty I have not tried the new P2K 2 Pro, but the old P2K that I have is an excellent motor with good torque best suited to tighter circuits.
Steevo
Old 04-27-2003, 10:38 PM   #26
Registered User
Calvin Ng's Avatar
will the Monster Horsepower Stock Pro be a diffrence with the Monster Horsepower Stock Motor?????
any tricks on testing if your over gearing like touching the motor??
if your using one of those temperature laser guns thing what temperature should it be at?
Old 04-27-2003, 10:48 PM   #27
fatdoggy's Avatar
R/C Tech Charter Subscriber
Generally if you can't keep your finger on the can for 5 seconds after a run your over gearing.
fatdoggy is offline   Reply With Quote
Old 04-28-2003, 08:49 AM   #28
Registered User
Calvin Ng's Avatar
the way steevo is gearing does it sound right to you??? its about 2.40 i think
will it damage the motor
Old 04-28-2003, 09:24 AM   #29
shrekair's Avatar
Trader Rating: 9 (91%+)
TEST AND SEE,
you will soon find out that we really cant help you for your specfic situation, just get you close.
the "pro" is just trinity's way of saying that the motor was spun up on a dyno, doesnt make any difference. dont get hung up on that.
buy a monster and try it, if it works, great, if not, more knowledge to you. everyone generally has a good feeling about them. as far as gearing, ask at your track.
shrekair is offline   Reply With Quote
Old 04-28-2003, 02:43 PM   #30
Steevo's Avatar
Hi Calvin,
I am not sure how you got the figure 2.4 but if you use the rollout figure (34mm to 35mm) that I gave you then that will be a good start. Exact gearing for your track can only be worked out by you. Do you know how to calculate rollout?? If not let us know and we'll show you.
Steevo
Stock Motor Lot w/Trinity case and Much More Motor Mate Racer4Life R/C Items: For Sale/Trade 2 08-19-2007 09:04 PM
Method to run-in stock to higher turm motor? or a stock tune to a higher turns? micro80 Malaysian R/C Racers 0 06-16-2007 12:40 PM
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 11:22 PM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
trade 11x2 like new motor for stock motor BuggyMulisha R/C Items: For Sale/Trade 3 11-08-2004 03:16 PM
