mirage competition 23T motor
hey i got one of these and i was wondering if it is any good
Re: mirage competition 23T motor
Which Mirage motor did you get..???
The Prisim
The Psycom
Or the Newer Psycoms with the yellow or red dot on the side of the can..??
The Prisim is more of a Torque Motor but it will turn some Rpms' on average about 29,000
now for the Psycom ..If you have the Yellow dot one.. they will Rip.. make sure that you gear it about 5.7~5.8 for most tracks.. because it winds..out ....But make sure that you have some good batterys I can almost dump mine in 8mins with one of these!!
-Dave
it's a prism motor with a blue dot so high tourque?
hey i was wondering what pinion should i put in it? like gear it between?
nvm with pinion stuff...i got it figured out....where should i start with gearing?
I would start the gearing in the 5.65 Rand and then ply with it going up or down a tooth depending on the track size....
Very good 23T motor... It's up there with some of my favorites
-Dave
Registered User
Team Orion has Havok stock 23Tx2, any good? Compare to Tamiya type-RR? Do anybody know where can I get Luna-s 23T motor online?
Registered User
you can get the Luna's on line from Control Center
Originally posted by JDM_DOHC_SiR
Blue dot
-Dave
Blue dot
-Dave
yay! got a good one! the track is pretty big...well there are 2 tracks one small one big...hehe and there was a 1:24 track
I use my Mirage on very tight tracks...it has lots of low end when I need it..and they run pretty cool too
-Dave
how much du you start gearing it?
