PRO RACER QUESTION! DEANS OR WHAT? >
Old 06-29-2007, 05:24 AM
ProudSavageOwnr's Avatar
Default PRO RACER QUESTION! DEANS OR WHAT?
OK here we go, wat do the PRO PRO racers use? corraly style bullet plugs? or the deans? im talknig resistance wise here.....i dont giv a dam bout polarity mixups, i wana know wat the pro azz racers use......
im with coraaly bullets, whos with me?
ProudSavageOwnr is offline
Old 06-29-2007, 05:29 AM
TylerOwenby's Avatar
wire it straight to motor and battery thats what the pros do (least resistance)
TylerOwenby is offline
Old 06-29-2007, 05:32 AM
and keep the soldering iron on
TAMIYAMANUK is offline
Old 06-29-2007, 06:06 AM
Drewdc90's Avatar
They direct solder to the batts, the best thing after that is corally plugs.
Drewdc90 is offline
Old 06-29-2007, 06:14 AM
rampal's Avatar
shortest possible cables and direct solder.....
minimum effort and "pro-flavour" alternative (although not strictly "pro"):
- shortest and cleanest installation
- always solder your motor to the ESC
- corally connectors for your batteries
and believe me, polarity mix ups happen in the best families....
rampal is offline
Old 06-29-2007, 06:25 AM
GymBeam's Avatar
pros get to change thier packs every race meet.
private guys who buy thier own, its not good to direct solder all the time, as the heat on the 1st and 6th cell will die first.
also much easier to have corally tube, especially when you are there practicing.
GymBeam is offline
Old 06-29-2007, 06:47 AM
SlamMan's Avatar
I've tried them all and find the Deans to be the easiest to deal with day in and day out.
SlamMan is offline
Old 06-29-2007, 08:38 AM
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Deans.
Least resistance tighter connection.
I use it on all my connections and make for a lot hassle in the pits when changing motors or batteries.
UN4RACING is offline
Old 06-29-2007, 10:00 AM
rc-zombies's Avatar
I use the 3.5mm mini Euro plugs.. similar to Carolly type..but smaller.
"Resistance if Futile"
rc-zombies is offline
Old 06-29-2007, 01:23 PM
CAi
Only soldering.
CAi is offline
Old 06-29-2007, 03:04 PM
CristianTabush's Avatar
The most efficient I have seen measured in terms of resistance is the Deans Ultra plug set-up John Stranahan came up with. If I'm not wrong, he measured equal or less resistance than hard wiring to the batteries. Ask him on his Pantoura thread to give you the specific links and specifications.
CristianTabush is offline
Old 06-29-2007, 03:46 PM
Tim W.'s Avatar
Direct solder
Tim W. is offline
Old 06-29-2007, 04:26 PM
gubbs3's Avatar
That's really not a problem. Direct soldering implies soldering to a bent battery bar. The bar dissapates a lot of the heat before it reaches the cell and doesn't push it past normal operating temperature.
gubbs3 is offline
Old 06-29-2007, 05:13 PM
I think most people don't want the hassle of soldering every time you run. Its much better to use plugs for the average racer. Also many clubs around the world don't have AC power which means soldering can be a hassle (but not impossible with 12V irons)
Mike
ixlr8nz is offline
Old 06-29-2007, 05:47 PM
FrankW's Avatar
The pros hardwire (direct solder). I hardwire because I race 12th scale and there isn't any extra room for excess wire and connectors. However, I would say most club level racers use Deans plugs.
-Frank
FrankW is offline
