lipo setup?
Old 06-28-2007, 06:10 PM
Default lipo setup?
ok im looking to get into lipo, im gonna go the orion way as they have had a lot of good comments and i just feel safer knowing their reputation, so im ordering 2 carbon spec 3200 packs a novak 2c smart stop and im chaseing a much more fan control, just trying to make sure i dont ruin my new packs.
is their anything else i should buy? oh im chargeing with an ice.
cheers, Josh P
aus jd 2703 is offline
Old 06-28-2007, 08:13 PM
Big B's Avatar
Good question for the Orion 3200 thread http://www.rctech.net/forum/showthre...ght=orion+3200
Big B is offline
Old 06-28-2007, 08:24 PM
yep posting there but i wanna know what guys use with lipo in general not with just one pack?
cheers though
Old 06-28-2007, 08:28 PM
kuzo's Avatar
You should be good with what you have there. One question about the much more fan setup. I'm not familiar with it, how does it hook up?
kuzo is offline
Old 06-28-2007, 10:44 PM
Rommel's Avatar
Great setup and if your running brushless get the motor heatsink. Its keeps everthing so cool. One tip with Novak cutoff, once it starts sputtering power stop, it seems to charge quicker that way.
Rommel is offline
Old 06-29-2007, 07:02 AM
so has any one used the fan controller before? i was lso thinking bout adding a 250mah lipo to power fans and stuff whats ya's think? will it help produce more power or is the drain of a few fans minimal?
cheers.
Old 06-30-2007, 07:22 AM
Phroz's Avatar
A charging balancer, i'd make sure u get one.. they are pretty cheap and will keep the battery in good health.
EDIT: Do these packs even have a balancing tap?
Phroz is offline
Old 06-30-2007, 07:32 AM
Mr. Shookie's Avatar
Yes and www.nexusracing.net has the orion lipo balancer and directions on how to make it work for these kinds of packs.
Unless you are running MOD I wouldn't bother with a cooling fan. You will just end up wasting space and weight...But if you feel you need it go for it.
-Shookie <><
Mr. Shookie is offline
