Old 09-07-2001, 11:09 PM   #121
Alvin's Avatar
Unhappy Car probleml suspect it is my ESC (or batteries)!!
Dudes,
I have a Tekin G12C... recently I've been more active playing with others on the track and something is MAJORLY wrong with my car and I'm wondering if it's the ESC... or batts.
This morning I took both my 3k nimhs to a parking lot track and damn my friend with a Pro3/14T double's runtime outlasted my car. Not only that, he was using only 1700mAh nicads!!!!
I run either a Yokomo 23T JS stock or Tamiya Dyna Run Racing (i think around 27T), I expected more run time from these stock babies.
Car doesn't seem to have any binding... If I disengage my pinion from the spur it freewheels very well.
A note: I am running my ESC with the current limiter disabled.
Battery wise:
3k phantom matched nimh: 5A charge 15A discharge rate - 8min50sec (average voltage @ 6.9x)
3k GP unmatched: 4A charge 15A discharge rate - 9m50sec (average voltage @ 6.6x)
Thanks for any assistance!
~Alvin
Alvin is offline   Reply With Quote
Old 09-08-2001, 10:36 AM   #122
fatdoggy's Avatar
R/C Tech Charter Subscriber
Probably that your charger is false peaking and you not getting a full charge. What sort of charger do you have??
fatdoggy is offline   Reply With Quote
Old 09-08-2001, 11:19 AM   #123
Regional Moderator
Darkseid's Avatar
I would agree with fatdoggy. Those NiMH cells can be tricky to charge if you don't have a charger ment to charge them.
TLR 22...Tamiya F104...
Old 09-08-2001, 10:03 PM   #124
Alvin's Avatar
fatdoggy/darkside, I'm using eaglemodel.com 's cdc charger. Which afaik is integy's 16x5...
I dropped my current limited to 80A max, seems to improve runtime. So much that my motor overheated
Old 09-09-2001, 09:42 AM   #125
Alvin's Avatar
Default Nevermind
dudes,
thanks for the assistance. But my tb01 just died today, rear gearbox total failure, I think this is what cause the motor to die (first time I see an armature blackened ).. Now running other touring car, thanks for all help!
Old 09-10-2001, 11:18 AM   #126
Regional Moderator
Darkseid's Avatar
Alvin: Good luck, I hope you get it all worked out.
Old 09-11-2001, 08:16 AM   #127
Alvin's Avatar
thanks alot Darkside! My new kit happened to arrive today, I will try to keep both cars around
Old 09-11-2001, 09:22 AM   #128
Default Re: Nevermind
Originally posted by Alvin
dudes,
Alvin, I just heard about ur problem via Yusman whom u met just now at Winnie's shop. What I suspect that cause ur gear to disfigures is might due to ur spur and pinion was too tight and also overgearing that cause ur batt to dump fast and motor overheated. If not mistaken ur are using 72spur with 38pinion (4.9 gear ratio). If that so means u r killing ur motor and batts. For ur info I'm using 88spur with 34pinion (6.7 gear ratio) on 23t Kawada Stock motor. In fact I did advised u at Winnie's place about the gearing. About the new car u just got I hope it's TAO4R. If not, what car is it? If u intend to buy a spare car for playing, I'm selling away my MR4TC Pro @S$250 with spare new chassis, upper deck and lots of others. If interested please SMS me @94885770.
Rose Money is offline   Reply With Quote
Old 09-11-2001, 09:55 AM   #129
Alvin's Avatar
Hi Ros,
Yes I got an 04r, can't wait to assemble it. Nearly wanted to get a HPI Pro 3 but nah... I want to go tamiya race. And their bodies fit the my tb01 & 04 perfect
Ros, actually i already gave up using 64 pitch gears on TB01, I have already spent like >20 bucks on just damn 64 pitch gears, I can't get them to mesh properly.
In any case when I was running 64 pitch with my 23T yokomo YS was 88T/35T, which afaik gave me ratio of around 6.5.....
With the 48 pitch gears I was running 58/24, around 6.28... I tried to gear higher since the motor I use then was a dyna run racing...
Meshing wise I'm think it's ok, there is play between spur/pinion. WIth the pinion disengaged car freewheels very well. I have a bad habit of stripping the car apart virtually every saturday night after Yuan Ching track.... usually I clean out all the grime and stuff...
BTW, u wanna know how hot the motor was? I ran it for about 2 laps, during the second lap the car already acted like dumping. Dumped on straight (Zoom RCM track). I took car back and usually I move it around my sitting area via the upper chassis, and I got a damn shock when I touched the shaft: it was hot. Motor itself was so hot I could feel the heat radiating from the heatsink.... even after I disconnected the motor from the motor mount ppl still had to use a thick cloth to hold it. Brushes changed from copper to blue silver. Dun ask why, my best guess perhaps when I play in the car park some sand or grit got into the can.
Why sell your MR4? U really going to Nitro?!
Old 09-11-2001, 12:42 PM   #130
fatdoggy's Avatar
Alvin I hope you like your 04R they look sweet.
Old 09-11-2001, 06:51 PM   #131
Alvin's Avatar
fatdoggy, thanks! Hopefully I can be easier on the throttle this time and don't wreck it as often as I do my tb01 :-)
~Alvin
Old 09-12-2001, 07:17 AM   #132
Alvin, why not playing at MS? Maybe it's too far for u. But it's much safer to play there. I barred myself from playing at Yuan Ching and Yishun tracks because it surface is not level (bumpy and damaged my chassis) and also had alots of sand (damaged my spur and pinion gear).
Right now since there's no electric race at this moment, I really enjoy playing my 1/8 buggy at Toa Payoh track.
Old 09-12-2001, 11:51 AM   #133
Alvin's Avatar
Ros, correct! Distance! Also the bus service is darn slow, miss one and that's it!
Actually in recently apart from my deformed gear incident, I haven't had much trouble playing at yuan ching... Yeah the carbon chassis hates it there... But I just put some glass tape can liao.... Saturday will test drive 04 there... hopefully. I need to convert all my deans to corally connectors - the TA04 chassis can't hold my side by side packs with deans.....
Old 09-12-2001, 07:41 PM   #134
Trader Rating: 68 (100%+)
does drive frequency have anything to do with runtime, punch and top speed? if you change the cyclone tc2's freq from 15khz to 23khz, will there be a noticeable increase in runtime? or will top speed and acceleration be slower?
marvi is offline   Reply With Quote
Old 09-13-2001, 09:54 AM   #135
zxt
zxt's Avatar
Default Duster Sport
I just got a used HPI RS4 Sport kit that came with Novak Duster Sport ESC...
Anyone using or used Duster Sport ESC here? What can u say about it?
zxt is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
