Old 03-20-2002, 08:38 PM   #571
Regional Moderator
Darkseid's Avatar
Cantbestopped: WailinOnYa told you the place where I saw it at that price.
They also had the Keyence ZeroV Extreme at a very reasonable price.
TLR 22...Tamiya F104...
Old 03-21-2002, 01:07 AM   #572
cantbestopped44: If you are considering the Integy chargers, don't buy direct from them you can save money by getting their chargers from places like www.stormerhobbies.com ! I don't know if Stormer has the best prices on Integy's line of chargers but they do have good prices and are cheaper than Integy direct! You'll have to check around to see if you can get them even cheaper somewhere else.
WailinOnYa is offline   Reply With Quote
Old 03-22-2002, 08:44 PM   #573
AO
AO's Avatar
Does anyone know which esc is the best?
AO is offline   Reply With Quote
Old 03-22-2002, 09:05 PM   #574
Alvin's Avatar
AO: Keyence Zero V Extreme, GM V12, Novak TC2..... Actually right now I'm pretty happy with the schulze eagle 3 I got... works ok i'm happy finally
See you next tamiya race, have to face your *gasp* 414M2
Alvin is offline   Reply With Quote
Old 04-09-2002, 08:45 AM   #575
Trader Rating: 69 (100%+)
ESC rated # of cells question:
i have an LRP F1 pro reverse esc (no motor limit) rated at 4-7 cells. will it work if i use an 8-cell pack? or do i risk burning it up? i saw in RCCA 2001 touring cars that the front drive dragger used a v7.1 and 12 cells, but the v7 is not rated for 12 cells. im only going to use dual mabuchi 540 motors on the esc. thanks for any info
marvi is offline   Reply With Quote
Old 04-09-2002, 08:13 PM   #576
ijnek's Avatar
Send a message via ICQ to ijnek
Smile
the keyence zero xtreme is 1 of the best esc around.featuring full digitial display...Kool esc i would say...
yes,u would risk burning up ur esc...not a risk 2 b taken lightly...
ijnek is offline   Reply With Quote
Old 04-09-2002, 09:54 PM   #577
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
Thats just like asking which fullsize car is the best. Everyone has thier own opinion that they think everyone else in the world should beleive.
-Troy
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 04-11-2002, 08:39 PM   #578
Joe
Joe's Avatar
Guys, I am selling my GM V12. Click here for details: http://www.rctech.net/forum/showthre...7806#post97806
Joe is offline   Reply With Quote
Old 04-12-2002, 12:43 AM   #579
fIShCaKe's Avatar
Send a message via MSN to fIShCaKe Send a message via Skype™ to fIShCaKe
Default NEWBIE IN ELECTRIC NEED HELP.
Hi guys, I am currently setting up my new Micro RS4, and am currently facing a difficulty in installing the Orion Elite Motor. As I am using the Novak Atom ESC, it is compulsory to attach a diode to my motor to prevent my ESC to fry( or whatever ). But, I've also noticed that there isn't anything attached to the Coreless motor. ( NO CAPACITORS TOO! ) Do I still need to install a Diode onto the motor? Is it alright if I don't??!!
fIShCaKe is offline   Reply With Quote
Old 04-14-2002, 05:54 AM   #580
Does anyone know if the LRP pro reverse speed controller with no motor limit is any good and does anyone know the motor lmit on a M. Tronik St 500 turbo. And finally I have just been given a Sprinter LRP forward/Brake speed controller that needs some attention is it worth the bother
jonnieknight is offline   Reply With Quote
Old 04-14-2002, 08:35 AM   #581
jonnieknight: are you referring to the LRP F1 pro reverse? well, i have this esc and its a nice and reliable unit. Im using it on my monster truck, running dual stock motors and a 7-cell pack. it barely warms up, even at slow speeds, and power and runtime are great. it also has a reverse lockout feature so you can use it for racing. even if it has no motor limit, i would still use a mild modified motor and conservative gearing. even if it is a high end reversing esc, its still not at the same level as top of the line racing esc's such as V7, cyclone, etc. For backyard bashing, this esc is more than enough.
another LRP esc you may be referring to is the LRP Quantum pro reverse. It has a 7-turn motor limit but this covers just about any racing motor (unless you prefer to use 6-turn motors) and its a newer model than the F1 pro reverse. i dont have one of these but i know that the quantum series are very small escs that will fit just about anywhere (compared to the much larger F1 pro rev)
Old 04-14-2002, 09:12 AM   #582
TFR
TFR's Avatar
fishcake, I have a Micro too.
about the Elite mod, it has built in Capacitor so don't worry about that.
and for this small little motors, a Diode is not necessary...
TFR is offline   Reply With Quote
Old 05-05-2002, 02:58 PM   #583
I need a bit of advice I have a LRP Runner with reverse and I cant get it to except reverse when I go to program it in it starts flashing a bright green light what is wrong
Old 05-05-2002, 06:15 PM   #584
dcracer's Avatar
Any real difference between the Novak Cyclone TC and the TC2 other than the detachable signal harness and the built in on/off switch.
dcracer is offline   Reply With Quote
Old 05-05-2002, 06:37 PM   #585
Impreza's Avatar
Send a message via ICQ to Impreza
I have 2 ESC's, a Tekin G10 and a Cyclone TC. Which one would be better for stock racing?
Impreza is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
