Old 11-21-2001, 10:17 PM   #406
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
A double post.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 11-21-2001, 10:18 PM   #407
Originally posted by TFR
Do you mean a cap on the ESC??
Yeah, I placed (soldered) a small cap on the ESC positive/negative radio leads to the RX. I had a twitch in the digital servo and the cap resolved that issue.
My standard (non-digital) servo bogged down the car exiting turns so I went to a digital servo.
V-Dezign 4.0
Old 11-21-2001, 10:31 PM   #408
MauiBuilt Racer's Avatar
What kind of servo was it?
MauiBuilt Racer is offline   Reply With Quote
Old 11-21-2001, 11:48 PM   #409
The old was Hi-Tech and the new is KO.
V-Dezign 4.0
Old 11-22-2001, 01:29 AM   #410
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
it was a futaba S3003 servo ... it makes it easier to drive compared to hi speed servo cause my car is set up VERY VERY twichy.
and i m wondering if S3003 takes that much curent !!!!!! or is it my reciever ??? or ESC???
Plz help
imataquito is offline   Reply With Quote
Old 11-22-2001, 03:14 AM   #411
Regional Moderator
disaster999's Avatar
the same problem happen to my brother's electronics....he uses 3pdf, cyclone tc, jeti receiver, and s9402...when ever the pulls the trigger, the servo twitchs really bad for a sec...then stables...and when he is about 50m away from the car, its like it gone out of radio range and act like crazy. its fine i use his remote on my GP...no twitch or glitch...its only his car!!
anyone know y?
disaster999 is offline   Reply With Quote
Old 11-22-2001, 03:32 AM   #412
Manticore's Avatar
R/C Tech Charter Subscriber
anyone know y?
it is the jeti receiver problem.
Manticore is offline   Reply With Quote
Old 11-22-2001, 03:36 AM   #413
Regional Moderator
really?? but the nitro uses the same receiver and nothings wrong wor!
Old 11-22-2001, 07:04 AM   #414
Your nitro RX is receiving direct power from the batteries instead of an ESC having to parse the signal between the motor and the RX. The motor could have an enormous draw on the system robbing what the RX deserves to function proficiently.
V-Dezign 4.0
Old 11-22-2001, 07:13 AM   #415
Plz help
I ran a cap on my high-speed .09 Futaba also. My RX and TX is KO. You must have confidence there is no debris in the RX. I had to clean mine because of a few rocks with metallic properties screwed it up BADLY. That may not be your case. Make sure the TX batteries are fresh, but based on what you described early we can excuse all the above.
Try a small cap and see if it improves your situation. I soldered mine at the point where that ESC plugs into the RX. I slid the female pin plugs out a bit an attached the cap. My problems with lack of power exiting turns was solved.
V-Dezign 4.0
Old 11-22-2001, 09:31 PM   #416
imataquito's Avatar
Ty Rc cadet .. i will ttry that but can u plz tell me the rating for the cap
must it be the low ESR cap like the caps u use on the battry wires?
what is the rating? Volts and uF.
i m gona check my Rx to see if thers any small rocks in it hehe maybe one or 2 just got in there.
i lose lots of speed exiting the turns...... and the sad thing is i HAVE lost of grip for the turn and i can easilly shoot out of it taking a slightly tighter linewithout having to worry about my car losing control ....( car is setup to mildly overstear on trottle)
Thanl U again RcCadet
Old 11-24-2001, 04:07 PM   #417
imataquito's Avatar
anyone knows the answer to the question below ?
Old 11-24-2001, 05:56 PM   #418
Default MRT VX Pro ESC?
Does anybody have any info on MRT's new speed controller? In case you have not heard of it, it was tested and reported on in the December issue of the Radio Race Car International Magazine. The only problem it seems to be manufactured by a UK company, (MRT) and I can't find a distributer or hobby shop that sells it.
Please help! I'm looking to try one of these.
Lee H is offline   Reply With Quote
Old 11-24-2001, 07:27 PM   #419
If you are referring to the cap, I am using a 4700uF 16v.
V-Dezign 4.0
Old 11-24-2001, 10:00 PM   #420
Send a message via ICQ to Ryan199
Im just wondering what you guys think of a Tekin G12 ESC? I can get it for $50 Cdn. Think its worth it?
Ryan199 is offline   Reply With Quote
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
