Old 11-19-2001, 11:55 AM   #391
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Originally posted by TCRboy
do the Quantums have replaceable wires? and a good spec or not, when compared to the prices of the IPC range?
The Quantum does have external solder points that the 7.1 lacks. The two share the same frequency but the Quantum is more programmable. The 7.1 has a higher current rating and ~1/3 larger.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 11-19-2001, 01:46 PM   #392
thanx m8
isn't the nosram dominator series made by lrp? what's the dominator (not the dominator power, i'm talking about the model below) like? i'll be running it in a yok mr4 TCR with a 19d (control motor)
cheers
TCRboy is offline   Reply With Quote
Old 11-19-2001, 06:17 PM   #393
JimmyMac's Avatar
When I said RCCA uhh.. I meant RC Car Action magazine website. So just go to rccaration.com and click on RC Zone, then Bulletin boards. Then go to uhhh Electronics. You could do a search for uhh like I said before I'll even bump the post up so you can see it if you go on tonight......
Jimmy Mac
JimmyMac is offline   Reply With Quote
Old 11-19-2001, 09:01 PM   #394
imataquito's Avatar
Send a message via ICQ to imataquito Send a message via Yahoo to imataquito
Thanks Kill Ruf i thought u said Radio Control Car Assiosation as in RCCA lol i looked everywhere for it b4 commin back to post
ok will check it now
TY
imataquito is offline   Reply With Quote
Old 11-19-2001, 09:47 PM   #395
thanx m8
cheers
LRP is the parent company now. Nosram was an early nineties success story and wilted away over time. LRP saved them from eminent doom and now they are back for good!
V-Dezign 4.0
Old 11-19-2001, 10:21 PM   #396
TFR
TFR's Avatar
Nosram = LRP...?
so is there any Nosram esc?
TFR is offline   Reply With Quote
Old 11-19-2001, 10:48 PM   #397
Originally posted by TFR
Nosram = LRP...?
Nosram will not be sold in the US anytime soon. LRP wants the US market.
V-Dezign 4.0
Old 11-19-2001, 10:54 PM   #398
redsand's Avatar
Send a message via Yahoo to redsand
what the operating frequencies are for ?
there are two choices on my v12, 2 & 4khz.
also, i need some input from gmv12 users concerning the setup values for my guidance. as of now, i set it up as follows:
#1 turbo (3)
#2 min brk (5)
#3 max brk (3)
#4 (factory setting)
i happen to use the 3PJ, when i set up my v12 with above values, i can't adjust the brake from the radio (ATL).
does this mean, i can only adjust the brake from esc ?
redsand is offline   Reply With Quote
Old 11-19-2001, 11:01 PM   #399
dtm
dtm's Avatar
Send a message via ICQ to dtm
#1 turbo (3)
#2 min brk (5)
#3 max brk (3)
In general;
Lower frequency = more punch
higher frequency = smoother response
Everyone has different preferences for the profiles. Just whatever you are comfortable with!
When calibrating your V12 make sure you have the ATL set to 100 otherwise the V12 may not recognise the brake input from the TX. Turn the ATL down after you have setup to reduce the braking.
dtm is offline   Reply With Quote
Old 11-20-2001, 02:38 AM   #400
redsand's Avatar
I have turned down the ATL value from 100% to 80%, the brake still seems a bit strong. Turning down more than 80, the esc starts to make a beeping noise with the red LED flashing.
Now what's up with that ?
Old 11-20-2001, 07:33 AM   #401
dtm
dtm's Avatar
Redsand: I'm going from memory here but try this test;
1. Plug a servo into the ESC channel of your reciever (put a servo horn on to make the servo movement more obvious).
2. Adjust the ATL (-ve) without touching the throttle trigger and see if the neutral position shifts.
3. Apply a tiny bit of forward throttle and see if the servo moves a 'tiny' bit off the neutral or whether it 'jerks' forward to a position.
Get back with the results!
You are running a 3PJ and not a 3PJS right?
Old 11-21-2001, 02:14 PM   #402
what difference does the amp rating on an ESC make to the performance of the car??
Old 11-21-2001, 08:50 PM   #403
imataquito's Avatar
more amp rating = more punch expecially when coming outa coners .... and in that way u accelerate faster
guys i need some help ...
i m gona get a GMv12xc soon real soon ...waiting 4 shipment ... the guy said not so soon
for now .. my curent ESC has got some big problem!!!
when i m comming out of the turn i punch the trottle but the car does not semed to accelerate untill i let off my stearing to neutral position b4 the car starts accelerating.
now thats LOTS of SECs lost there. still cannot figure out whats wrong except the ESC has its timer ticking close to the end of its life time.
Old 11-21-2001, 09:18 PM   #404
Is it a digital servo? Are you using a 4700uF cap on the receiver?
V-Dezign 4.0
Old 11-21-2001, 10:11 PM   #405
TFR
TFR's Avatar
Do you mean a cap on the ESC??
New to the forum mig rod Electric Off-Road 1 01-05-2008 05:23 PM
hi i need help and im new to the forum racer4 Rookie Zone 4 01-21-2007 02:37 PM
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
Forum Changes... futureal Wisconsin & Illinois Racing 3 10-28-2002 09:26 PM
