Old 06-26-2007, 09:35 PM   #1
Mitchell's Avatar
Trader Rating: 15 (100%+)
Default balancing wheels?
i have heard that you can balance your wheels by putting blue tac in the right places. does any one have any tips on doin this?
___ _________________________
___ |__|__|__|__|__|__|__|_____\
____ |__T Associated fan bus _|_| __\_
____ |_________________ |_| ____|
____ |_(@"@)____________|_|(@)__|
HOP ON BOARD!!
Mitchell is offline   Reply With Quote
Old 06-27-2007, 06:33 AM   #2
vtl1180ny's Avatar
R/C Tech Charter Subscriber
Get a Prop/Wheel balancer...
I still lurk....
vtl1180ny is offline   Reply With Quote
Old 06-27-2007, 07:23 AM   #3
RCSteve93's Avatar
Yes, as vtl1180ny said, put the wheel on a prop/wheel balencer, spin the wheel(it should spin smoothly and easily). Let it stop. Mark the bottom, and apply clay of some sort to the opposite side. Repeat the prosses again, removing and adding clay until the marker side or clay side does not face down. Then the wheel is balenced. By the way, I am just taking this from a XRC magizine article. I have never balenced a wheel.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 06-27-2007, 12:23 PM   #4
vtl1180ny's Avatar
I don't bother balancing foams, matter of fact I've always found them to be perfectly balanced....
What I do balance are my Stadium truck and Buggy wheels... I find those to be WAY off balance...
I have rolls of lead tape... You can get them at a golf or tennis shop...
I still lurk....
Old 06-27-2007, 12:41 PM   #5
over gear's Avatar
is it useful? after 1 lap, the inserts shift and the balance will be off again.... unless u glue down the inserts too.
over gear is offline   Reply With Quote
Old 06-27-2007, 01:05 PM   #6
Mason's Avatar
every little bit counts. some guys CA really small objects they find in the bottom of their pit box. lol
Mason is offline   Reply With Quote
Old 06-27-2007, 03:22 PM   #7
Elboogie's Avatar
ditto.
CYCLONE WCE
Jaco / Airtronics
Much More / Team Orion
"Drive Hard or Go Home"
Elboogie is offline   Reply With Quote
Old 06-27-2007, 05:43 PM   #8
RCSteve93's Avatar
True, but I have noticed that some of the older tires are way off, the new Parmas and Jacos are perfect once you true them.
rm -rf /windows
Old 06-27-2007, 10:55 PM   #9
Mitchell's Avatar
ok thanks for that
HOP ON BOARD!!
Old 06-28-2007, 01:03 AM   #10
SWTour's Avatar
we USE to balance FOAM tires with pins w/ the heads cut off.
stick them into he side of the foam tire, close to the wheel. (almost everything else was too heavy)
Never really saw it make much difference once we started having tire truers, but in the old days when we just mounted donuts - and didn't have anything good to cut them down with - we saw some change.
GOLF tape weight works really good for balancing TC tires along with CAPPED Oval tires, usually available at a GOLF PRO SHOP
SWTour is offline   Reply With Quote
Old 06-29-2007, 01:21 AM   #11
QuickRC's Avatar
Like Vtl1180ny said, buggy and stadium truck tires really need it. Rev your motor and watch your suspension shake allover the place from the out of balance wheels and imagine what that does for your handling and traction.
I use hot glue on the inside of the wheel. Easy, cheap and it can come off if you want it to but won't fall of on it's own
Use a prop/tire balancer - any type will do as long as your wheels will fit in there.
I don't balance my TC tires, BTW.
Brad
www.QuickRC.com
QuickRC is offline   Reply With Quote
Balancing Truggy Wheels SKOT Nitro Off-Road 40 02-28-2010 07:56 AM
balancing a lipo help TeckLancer Radio and Electronics 1 08-06-2008 05:46 PM
Lipo Balancing Help dougyunker Radio and Electronics 2 07-25-2008 06:08 AM
Tire Balancing???? playboy Nitro Off-Road 5 04-09-2008 02:49 PM
wheel balancing pug 205 gti Electric On-Road 10 02-12-2007 06:16 PM
