Old 04-25-2003, 10:11 AM   #16
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Hardwiring = less wire length, which = less overall resistance in the connections, which = more speed
I've hardwired for about a year and a half now and would never go back to even deans plugs. Solution to rushed solder joints....Solder the pack in BEFORE you repeak or several minutes before you race so you have time to make a good joint. Good soldering irons help a lot too, like Trinityracinnut said, get a good quality iron with a decent sized tip and you're set .
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 04-25-2003, 01:22 PM   #17
odpurple's Avatar
It is much cooler to hardwire than to use plugs. And car will look cleaner (providing you can solder).
Also, chicks dig guys that hardwire! Swear to God, it's true!
O'D
odpurple is offline   Reply With Quote
Old 04-25-2003, 08:53 PM   #18
popsracer's Avatar
Default Re: Re: Re: hard wire
Originally posted by howard hudson
HUMMMMMMMMMM just for stock racing> thats explains why you cant catch me lose the plugs bud atleast the one at the motor
I'm going to have the Paramedics handy cause that day is coming soon.
popsracer is offline   Reply With Quote
Old 04-25-2003, 09:58 PM   #19
howard hudson's Avatar
Default Re: Re: Re: Re: hard wire
gggaaaawwwhhahahahahahahah I dont think so pal just keep using them there plugs buddy
what the heck is r/c car??? ( said in your best redneck voice)
'OL BUZZARD FARMING (lol)
howard hudson is offline   Reply With Quote
Old 04-25-2003, 10:00 PM   #20
well said!!!!!!
Old 04-25-2003, 10:16 PM   #21
Yeah I think you'll need more than that to help you around the track.. But Novice drivers always use deans on there motors.,,Don't call the Paramedics you don"t burn you finger's you use DEAN'S !!!!!!!!!!!
Mark Barden .
mb racer is offline   Reply With Quote
Old 04-25-2003, 10:48 PM   #22
O'D
so chicks like theHARD wire....
Old 04-25-2003, 11:38 PM   #23
LOL
USVTA Member #211
Old 04-25-2003, 11:54 PM   #24
popsracer's Avatar
Default Hard Wiring, the Hard way
You Guys better watch it or I might switch brands.
Old 04-26-2003, 06:51 AM   #25
Default Re: Hard Wiring, the Hard way
Old 04-26-2003, 11:39 AM   #26
odpurple's Avatar
I've also been testing hardwiring as a cure for baldness. The test has been underway for years now and I'm afraid it's going the other way...
O'D
Old 04-26-2003, 03:41 PM   #27
popsracer's Avatar
Default Going BOTH ways
O'D
That's because you need to solder each the wires to your Thumbs. Left is positive, right is negative (or is it the other way around).
Use an old lamp cord instead, then it wont matter either way.
Old 04-26-2003, 03:44 PM   #28
popsracer's Avatar
Default hard times with Hard wires
lose the plugs bud at least the one at the motor
on second thought leave them I like passing you
OK, the Motor Plugs are Gone . That mean your not going to let me borrow your 2400 pack now?
Old 04-26-2003, 04:26 PM   #29
THeGame's Avatar
Send a message via AIM to THeGame
Hard Wiring is the way to go. Its not the fastest way to get your batts and motor out tho... But i do it on all my cars..
THeGame is offline   Reply With Quote
Old 04-26-2003, 06:42 PM   #30
Default Re: hard times with Hard wires
CHIPS ANYONE?
7.2 v KO servo wiring & PT wiring issues bshookup Radio and Electronics 2 06-12-2008 01:23 PM
Hard Wiring???? jhigga15 Electric On-Road 7 02-24-2005 08:10 AM
Hard wiring batterys berger Electric On-Road 31 11-11-2003 09:47 AM
Best solder to use for hard wiring batteries? Accord Electric On-Road 25 05-14-2003 02:00 PM
HPI Sport2 - die hard, mega hard ! Cole Trickle Electric On-Road 6 07-07-2002 12:40 PM
