Help With MIP 1/10th Tweak Station >
Old 06-28-2007, 09:45 AM
  #16
timmay70's Avatar
I think that droop should be set after tweak. Setting tweak changes the ride height and will change how much droop the car has on the side(s) of the car that was re-adjusted...
timmay70 is offline
Old 06-28-2007, 09:51 AM
  #17
timmay70's Avatar
Originally Posted by A. Rhodes View Post
When using a tweak station, you are checking the end of the car on the non-pivoting part of the station. So if you have the front wheels on the pivot, and the rear wheels on the stationary, and the bubble is out of level, the rear of the car is tweaked. And vice versa for the front.
The tweak station is only showing how the car is cross balanced. If the bubble is down on the left with the front on the balance, it will be off to the left with the rear on the balance... Try it.
Shane's article has you tweak the front suspension to the rear chassis, then the rear suspension to the front. I skip that step by just throwing all four wheels on the station and tweaking them all at once. Bad, maybe, but it gets me on the track pretty quickly, and I got this habbit from guys that place in the A-main at large events... Even in Shane's article he shows that swapping ends on the station is useless.
timmay70 is offline
Old 06-28-2007, 10:02 AM
  #18
SlamMan's Avatar
Originally Posted by Outofcash View Post
Here's a link to XRC Magazines how to section that describes how to adjust tweak. http://www.rc411.com/pages/howto.php?howto=2&page=3
That was a good read.
I just don't see how that works. With all 4 wheels touching the tweak station they're all effecting the bubble level on the front. The front or rear shock collars can be adjusted to bring the bubble back to level.
The only way to eliminate the tweak on one end from another would be to use a droop block like in the XRC article above.
SlamMan is offline
Old 06-28-2007, 10:20 AM
  #19
Trader Rating: 32 (100%+)
Because when you have two wheels on the stationary part, and two wheels on the level, the excess load from the wheels on the stationary part, will show on the level side of the station as out of tweak.
Example - front wheels on level, rear on stationary. Level goes high to the left wheel, excess load on the front left wheel is resulting from excess load from right rear. You would decrease spring preload on right rear shock, and increase spring preload on left rear shock.
A. Rhodes is offline
Old 06-28-2007, 03:01 PM
  #20
SlamMan's Avatar
If you spin the car in the example above 180 degrees and place the rear wheels on the level the bubble would still read the same. Does that mean it's the front now that's tweaked?
In the example if the front shocks were adjusted by decreasing the front left preload and increasing the front right preload it would also bring the bubble back to level.
This isn't to say that adjusting the preload on only one end doesn't work though.
SlamMan is offline
Old 06-29-2007, 06:52 AM
  #21
I was just referring to the Hudy set up guide in my post. Everyone has there own method for adjusting tweak. Just remeber, if you need to adjust more than a little pre-load to get the car tweaked, there is usually something else wrong with the set up / chassis and should be addressed.
