Traction Roll
Old 06-26-2007, 02:12 AM
penmark67's Avatar
Trader Rating: 14 (100%+)
Default Traction Roll
Wondering how to limit the effects of traction roll on a Tourer.With ten years of racing i havent had this before. Its not corner speed as other drivers are the same speeds, not tyres as we are using same compounds.
Ps we race on a grippy bitch track, Help , ideas Thanks MarkM
penmark67 is offline
Old 06-26-2007, 02:51 AM
more$thanbrains's Avatar
possibly try less droop for less bodyroll
imo
more$thanbrains is offline
Old 06-26-2007, 05:43 AM
Skiddins's Avatar
Try using this;
There is also superglueing the sidewalls of the tyres so if the car tries to grip via the sidewall the glue won't allow it.
Skiddins is offline
Old 06-26-2007, 02:23 PM
birdy's Avatar
try stiffer springs and lower ride height i ad the same problem at one point
birdy
birdy is offline
Old 06-26-2007, 02:54 PM
Add sway bars or go with a thicker bar if already using.
porschejim911 is offline
Old 06-26-2007, 04:20 PM
Tek Nickal's Avatar
Things I would do are:
Make your roll centers as low as you can (camber link more parallel to the arm)
Also make the camber link as long as you can
Make your shocks more horizontal, lay them down
Run the thickest sway bar you can in the front
Glue the outside sidewall of the the tire
Reduce the amount of droop
Run stiffer springs
Some of these were already mentioned
Tek Nickal is offline
Old 06-26-2007, 04:29 PM
F. Mendoza's Avatar
Trader Rating: 79 (100%+)
Originally Posted by birdy View Post
... ride height ...
F. Mendoza is offline
Old 06-26-2007, 04:32 PM
Tek Nickal's Avatar
Well I'm assuming its a carpet track, where there's a limit how low your ride height can be, usually 5 or 4mm.
Old 06-26-2007, 08:30 PM
bmr
Trader Rating: 27 (100%+)
Good info on the chart. Thanks for posting it.
bmr is offline
Old 06-27-2007, 02:53 AM
penmark67's Avatar
Default Thanks to all
Thanks to all
