project nitrokiller >
project nitrokiller
project nitrokiller
Old 06-25-2007, 01:33 PM
ghiro's Avatar
Default project nitrokiller
Hi folks! I'm lookimg for some help to realize my project,i've read the 1/10pan car thread but whthout etting to the points i'm looking for.The car is a nib corally c10x that i want to race against some nitro sedans (nope! no RTR's!).First problem i've is find a body,then tires.I'm planning to use a Quarck comp. esc but i dont have any idea yet what motor to choose.Any suggestion is wellcome.
ghiro is offline
Old 06-25-2007, 02:02 PM
trjracing's Avatar
What kind of racing you plan on doing? Drag racing or track racing?
trjracing is offline
Old 06-25-2007, 02:04 PM
trjracing's Avatar
Go brushless if you going to track race and if you plan on drag racing go brushed.
Old 06-25-2007, 03:23 PM
ghiro's Avatar
I'll use it for on track racing and i already have a Quarck comp.Esc for it so i'll definetly go for a sensorless motor.
ghiro is offline
Old 06-25-2007, 03:32 PM
trjracing's Avatar
Cool, Try a mamba max motor 7700kv. Good Luck...
Old 06-25-2007, 03:41 PM
ghiro's Avatar
check the links to see two of the 4 tracks in wich i'm planning to use the car: www.gmradio.it then click "pista" www.hermesmodellismo.it click "la pista"
ghiro is offline
Old 06-25-2007, 04:06 PM
ghiro's Avatar
well,i thought about it but it doesn't fit,also Velocity motors wont.
ghiro is offline
Old 06-26-2007, 02:57 AM
more$thanbrains's Avatar
a question and an idea
question
are you siro?
idea
NEU motor
more$thanbrains is offline
Old 06-26-2007, 04:02 AM
MikeXray's Avatar
Trader Rating: 73 (100%+)
John Stranhan already has built the car that you need: http://www.rctech.net/forum/showthread.php?t=127484
MikeXray is offline
Old 06-26-2007, 05:39 AM
Drewdc90's Avatar
I've just started running my pan, here are the tyres and body i run:
http://www2.towerhobbies.com/cgi-bin...&C=CJJGAN&P=SM (bottom)
http://www2.towerhobbies.com/cgi-bin...?&I=LXZY95&P=0
If you are after an actual pan body stormer have a few:
http://www.stormerhobbies.com/cgi-bi...umb=on&smode=0
And you can check out John's thread for more sites.
Drew.
Drewdc90 is offline
Old 06-26-2007, 09:07 AM
ghiro's Avatar
Originally Posted by more$thanbrains View Post
a question and an idea question are you siro? idea NEU motor
siro? . . . only heard about Neu motors,where can i see/buy it ?
ghiro is offline
Old 06-26-2007, 12:24 PM
tallyrc's Avatar
velociti motors fit in pan cars.. atleast they fit in mine and all the peiple i have talked to.. you may need to bend the motor tabs, or swap out the new tab ring for the old "pass thorugh" type..
my MAX10 with velociti..
tallyrc is offline
Old 06-27-2007, 01:13 AM
about the neu motor
talk to b4maz
he has one for his 200mph car
Old 06-27-2007, 01:27 AM
Drewdc90's Avatar
You wouldn't need that much power to beat a nitro car.
Drewdc90 is offline
Old 06-27-2007, 05:57 AM
trjracing's Avatar
I'm with you on that one...
