Old 06-23-2007, 08:22 AM   #1
Default Need help with gearing for ta05r
I've been thinking about get the ta05r and im not really sure what size pinion gear to put in it the spur gear i know is 105 tooth and the motor i'll most likely be running in it is a 10T. If anyone could help me out that would be great!
vh1010 is offline   Reply With Quote
Old 06-23-2007, 08:59 AM   #2
Trader Rating: 16 (100%+)
I did stock, stock 13.5 brushless, 10x3, 8x1 and 4.5 brushless (except 19T and 10.5) on my TA05R...1st thing to do is save that Tamiya 105T and buy yourself a regular 64P spur gear (kimbrough or robinson). Tamiya gear is a little bit different from the standard 64P. They are like 0.4 module gear (correct me if I am wrong).
I use 108T (the biggest that you can use on TA05R)...and on a 10T, I use 25,26,27 pinion...FDR around 9-9.5 with rubber tires. Of course, that is the safe side of the FDR. I use mostly brushless now for MOD...on 4.5, I use 28/29T that gives me sub 9 FDR...not a problem except I don't think Ta05R drivetrain can take the MOD power for too long....car is more fit for using 19T and slower motor (my opinoin only)....
DO NOT use Tamiya TA05 Spool unless you have the wider toe block or size 46 CVD bones...it rubs and with mod motor, your front end will be trash.
Old 06-23-2007, 04:00 PM   #3
So 108T 64p spur gear and what pinion would i want to use on a stock motor and do you know of any good stock motors? and thanks for a ton for all the info
Old 06-25-2007, 12:35 AM   #4
gearing i'm not to sure. my wife's TAo5r is on it's way. for a stock motor. any Co27 based from any good motor builder will be good.
cyrrus is offline   Reply With Quote
new in box TA05R snopro31 R/C Items: For Sale/Trade 3 03-16-2009 04:15 PM
TA05R GSP R/C Items: Wanted to Buy 0 01-27-2008 10:56 PM
ta05r set-up fred71 Rookie Zone 1 08-02-2007 06:06 AM
TA05R + ESC for sale. nexxus Australia For Sale/Trade 7 04-17-2007 08:00 AM
TA05R or TRF415? p_mihai_ro Electric On-Road 10 03-21-2007 11:33 PM
