Old 06-22-2007, 05:48 PM   #1
surrealmaterial's Avatar
Send a message via MSN to surrealmaterial
Default Lathe Help
Hey Guys,
I have a com lathe with a carbide cutter. Problem is, when im cutting my com the whole thing just stops..........Im running it at 5v with a 540 motor......do i need to sharpen the cutter?(how?) or do i need to run it at a higher voltage?
Cheers
Castle Hill Raceway
surrealmaterial is offline   Reply With Quote
Old 06-22-2007, 05:56 PM   #2
STARSCREAM's Avatar
some will probably disagree with me....but I would recomend just getting a diamond bit as soon as you can....if you get one you wont ever have these kind of problems...
later,
Sean
Sean Maybell
Team Associated/Reedy/LRP
STARSCREAM is offline   Reply With Quote
Old 06-22-2007, 06:33 PM   #3
yes i agree with you but soon i will be going to brushless.......i only need a solution to this so i can finish off the last few weeks of the pointscore.....
Castle Hill Raceway
Old 06-22-2007, 06:35 PM   #4
Big B's Avatar
Get a Integy Lathe Motor 55t
Big B is offline   Reply With Quote
Old 06-22-2007, 06:39 PM   #5
Big B's Avatar
Just a guess, but are you using a Duratrax Ice to power it?
Old 06-22-2007, 07:19 PM   #6
maxepower's Avatar
Default Lathe issues!
What slave motor are you using. Even with a dull carbide cutter it should cut something. I only take .0005 at a time at 2 volts,which is half the distance between the lines on the scale of the wheel. Using the proper motor it should cut something even at 2 volts. Like the previous comment a high turn such as a 55 turn motor is the proper slave motor to use. Lots of torque!!!
A sharp tool bit is important, under a magnifying glass the tip of the cutting edge is rounded or chipped this will cut but leave a bad finish. One last thing,
make sure the motor is rotating in the right direction. Rotating into the flat side of the cutting edge!
Just my 2$
maxepower is offline   Reply With Quote
Old 06-22-2007, 07:33 PM   #7
Super Moderator
Grizzbob's Avatar
Right, & also be sure that whatever you use as a power supply for it can supply enough amps to keep it going(& as they said, 10 amps without having something like Integy's 45 or 55 turn motor as the slave could be the reason why it stops, slave motor may be needing more amps to keep turning & it can't get it)......
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 06-22-2007, 07:52 PM   #8
Jim S's Avatar
Trader Rating: 30 (100%+)
Send a message via AIM to Jim S
the ice motor run in is ove loaded use a turbo to cut the com to much load
Jim S is offline   Reply With Quote
Old 06-22-2007, 07:56 PM   #9
Send a message via ICQ to rcnewb2004
I think there is something wrong w/ ur 540. try a different motor... should be no problems.
rcnewb2004 is offline   Reply With Quote
Old 06-22-2007, 09:05 PM   #10
you can use 1500 fine grit sand paper to sharpen your carbide, never alter the angles and make sure that you do not round the edges as you can never sand them down far enough for it to sharpen again.
cut very little at a time and always lubricate the commutator and carbide, the sharpie trick works well on lubricating as well what you do is you cover the comm with sharpie, you can always add more lubrication by placing additional oil into the comm and the v blocks then cut VERY little at a time until all the blank ink is gone.
imel24 is offline   Reply With Quote
Old 06-22-2007, 09:53 PM   #11
thanks for the help guys........ill try a few of the things mentioned and it should be solved....
Cheers
Castle Hill Raceway
Old 06-25-2007, 05:12 AM   #12
tc3team's Avatar
whilst on the subject of lathes, how often do you guys carry out maintanence to your slave motor? And what would your schedule be for it?
Blast out the slave motor with motor spray and oil the bushings with a drop of oil? Got my lathe 2nd hand so im not sure when it was last serviced.
thanks for the advice
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
XXIP Comm Lathe and Orion Quick set lathe vino1 R/C Items: For Sale/Trade 2 01-25-2008 04:35 AM
Trinity Tru Lathe Motor Comm Cutter Lathe maximum R/C Items: For Sale/Trade 4 05-14-2007 04:56 PM
XIPP Super Lathe 3 / (pics) comm lathe diamond bit evostyle R/C Items: For Sale/Trade 8 12-01-2006 12:53 PM
Motor Lathe (Integy Xipp X-Mod Super Lathe) Geppetto R/C Items: For Sale/Trade 15 01-27-2006 05:10 PM
Tire Lathe, Motor Dyno, Comm Lathe For Sale 17Mark71 R/C Items: For Sale/Trade 8 06-05-2005 01:07 PM
