Old 05-01-2003, 03:56 PM   #16
Mr. MR4's Avatar
trinityracinnut - do u have the part numbers of the springs you use on the motor
Also, what gearing do u recommend?
Mr. MR4 is offline   Reply With Quote
Old 05-01-2003, 04:50 PM   #17
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I use trinity red(RC4389s) springs, and trinity green(RC4028s) springs.
MR- what car are you running? foams(size also) or rubber? size of track? type of track?
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 05-02-2003, 02:32 AM   #18
Mr. MR4's Avatar
I'm running at TC3 now (Rubber Tryres) - I havent tried your motor set up yet but I will be trying it out when I manage to get The Chameleon motors.
Regarding the gearing - I will be racing at the KO Grand Prix in August & I was told that the track has a 40 Foot straight!
Thanks for your help
Old 05-02-2003, 03:56 PM   #19
Moderator
MR- I would gear this motor at a 7.7 to start with then, gear it till when a 5 min run is over, u can hold ur thumb on it for at least 2 secs.
SMC Racing
Old 05-26-2004, 08:19 PM   #20
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
trinityracinut......
do you really put teflon shims against bearings?!??!?!??!?!?
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 05-26-2004, 08:59 PM   #21
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
motor heat isnt the true way to gear a motor properly. all motors get hot.(try using the thumb method in mod) the best way to see what gearing u should use is to have a look at the comm after each run. its colour indicates whether the motor is geared properly. best colour to get would be very slight pink tinge to it
dontfeelcold is offline   Reply With Quote
Old 05-26-2004, 09:30 PM   #22
Mr-s413bt's Avatar
Hey Guys.
Well i had some runs with my 19t peak dynasty on the w/e. Was 100% stock geared right up in a HPI pro3 final drive was 5.9:1
Don't ask me about roll out as i am an offroad racer .
I trued it yesterday and took very little off it, i could have kept using it (it had 14 runs on it).
Ooh that was on rubber tires aswell.
Glenn
Mr-s413bt is offline   Reply With Quote
Old 05-26-2004, 09:43 PM   #23
ottoman's Avatar
R/C Tech Charter Subscriber
Well Stephen must know something... he just TQed and won the 19 turn class at the big race in Tulsa a couple weeks ago.
Hey Stephen when did you get a Robi?
ottoman is offline   Reply With Quote
trinity dyno,integy spring dyno,new g11 speed contorls,and more Warren Weaver R/C Items: For Sale/Trade 64 05-01-2008 10:30 AM
Modded V-Spec dyno results Maximo Nitro Off-Road 0 01-05-2008 02:22 AM
Motor Dyno Numbers for Spec Motors gunlocators Electric On-Road 2 04-09-2007 05:58 PM
V-SPEC, 2050 PIPE, XXX-4, FANTOM DYNO FOR SALE rgb24 R/C Items: For Sale/Trade 5 09-24-2006 09:15 AM
Integy Indi Dyno v2 motor dyno SpeedChair R/C Items: For Sale/Trade 4 08-14-2006 10:30 PM
