Old 08-27-2007, 09:04 AM   #136
RaceAce701's Avatar
Trader Rating: 86 (99%+)
got a q for u all
about how many teeth did you go up from brushed stock to
brushless stock(13.5) in touring
The more to answer the better and tell me what brushed motor u ran
I ran a novak 13.5 offroad and i went up 9 to 10 teeth from the monster stock i usually ran
thanks for the help
The Skid Marks -- 24 Heures Du Jackson 9/22-23/2011
"Go for broke or go home broke"
"If it ant broke your not trying"
Alex "ACE" Kubilus
ACE design works
RaceAce701 is offline   Reply With Quote
Old 08-29-2007, 10:02 AM   #137
jrxs-r's Avatar
Originally Posted by RaceAce701 View Post
got a q for u all
thanks for the help
Try starting 4 teeth more and adjust accordingly...
Cheers,
Zack
___________________________________________________________________________
Proudly Sponsored by Stanbridges Hobbies
Serpent S411
jrxs-r is offline   Reply With Quote
Old 08-29-2007, 01:11 PM   #138
syndr0me's Avatar
Trader Rating: 32 (100%+)
Man, this motor has some grunt out of the corners.
syndr0me is offline   Reply With Quote
Old 08-29-2007, 11:43 PM   #139
Verndog's Avatar
Trader Rating: 16 (100%+)
Questions on sintered rotor
Got it installed this eve. and a couple things I noticed.
1) it was .080 shorter on the pinion end so now my pinion "hangs over" about that amount on my TC5. With the bonded rotor it was perfectly flush when aligned.
2). It seems to be a bit more noisy at real low speed...kinda a cement mixer sound if you were running slow enough to juice your tires. It also is way tougher to turn by hand...far more then the bonded and completely different then all my Mamba motors. Feels alot like a stock brushed to turn by hand..possibly tougher to turn. Is all this normal?? It seems to run just fine on the bench...I plan to get to the track tomarrow.
Update on ratio.
I'm now at 5.78 and that is perfect for a mid-small 13 sec. asphalt track. Running around 150 degs at 8 min runs. (Still on bonded rotor till tomarrow).
--->Dial-a-Grip for TC6
Kevin -- PPDBillet---TC6---Exoray 008
---Team Hoarders---
Verndog is offline   Reply With Quote
Old 08-30-2007, 04:05 PM   #140
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Update on ratio.
Thats what a sintered rotor does
That is all normal
And are you shure the shims are correctly on the rotor? That might be why it is shorter... I dont know if thats how this motor works, But I know my novak 13.5 does
BlackedOutREVO is offline   Reply With Quote
Old 08-30-2007, 09:36 PM   #141
Tech Legend
Wild Cherry's Avatar
Update on ratio.
The grinding noise is from the pinion side bearing , replace it ...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-30-2007, 10:50 PM   #142
syndr0me's Avatar
I find the shafts on the sintered rotors for these motors is much softer than Novak's. Mine is all chewed up from the set screw, and had to be filed so I could get a pinion back on. And that's after only two race nights. I've been sliding pinions on and off my Novak for a year without so much as a scratch.
Old 08-30-2007, 11:05 PM   #143
GreaseMonkey's Avatar
I ran the LRP 13.5 for the first time this evening. I geared it at a 32.5 rollout and it ran about the same top speed as a CO27 while having much more punch out of the corner. Temperature was 135-145 degrees which is pretty close to what we have been running the Novak bonded 13.5 w/o having to worry about ruining rotors. It was my first time running Lipo and Brushless and I'm really quite happy with it. My lap times were so consistent it's not funny.
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 08-30-2007, 11:16 PM   #144
Verndog's Avatar
That is all normal
.080 is one heck of alot of shim. I saw no shim when I removed the old one, and after assembly there was very little end play...possibly .010.
Also the pinion side bearing felt fine when I checked it while replacing the rotor ...and I seriously doubt it failed in 10 runs. The noise is only at VERY low speed. Goes right away with any real "useable" rpm.
Ran it today and it ran great. Temps dropped a good 10+! Off the track 12 min. run at 142. Wow...sweet setup. Are you reading Tekin?? You snooze you loose. Possibly a bit more low end, but... I too do not see a REAL noticeable change in power...more like slight.
---Team Hoarders---
Old 08-30-2007, 11:23 PM   #145
Tech Legend
Maybe your right , but that sound is still a indication...
They R Cheap , I use Ae rear axle bearing`s (teflon seal)....
Work, very quite & last long, long, time ....
George W. Cherry
Old 08-31-2007, 05:05 PM   #146
Ooops, I read that wrong, I thought you said .08 lol... Sorry about that
Thats alot less, But does it matter anyways?
Cool, thats nice low temps, you could gear up another tooth or 2 easily, I want more BL motors lol, My novak is cool, But I really wanted the LRP
Old 08-31-2007, 05:24 PM   #147
Verndog's Avatar
You prop. thought I said .008 or eight thousandths.
Correct...at this point it doesn't matter. Just wanted confirmation this was normal I suppose. I may gear up but really like the quick acceleration out of corners...seems at this point to be more benificial then a touch more top end on our home track at least. There was zero fade even after 10 mins. with both IB4200's and GP4300's. I'm very impressed with this combo so far...thank you LRP!!
A friend of mine thought they may have intentionally made it shorter to easily ID what rotor was in for racing regulation?? Not sure, but I can tell by looking now that I've made the swap.
---Team Hoarders---
Old 08-31-2007, 11:49 PM   #148
Thats true, It might be short for that reason, IDK
And yeah me too! I like the punch
Old 09-02-2007, 04:38 PM   #149
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
if anybody is looking for a LRP 13.5 i have one for sale with the sintered rotor and a brand new spare rotor , i only have 1 battery pack run through it .
http://www.rctech.net/forum/showthread.php?t=179677
Old 09-04-2007, 06:39 AM   #150
Ok guys, just got hold of the LRP Eraser 15.5 ( as it says that is more like a stock that the 13.5) and want to race it at my local club.
Track is indoor on primafelt type carpet and is fairly small ( down to around 10 sec laps depending on track layout )
Can someone please give me an idea for gearing to start with as I have absolutely no idea at the moment where to start ??
speedfreakUK is offline   Reply With Quote
