novak 13.5 sinterd rollout? >
Old 06-22-2007, 12:57 AM
Default novak 13.5 sinterd rollout?
I Just got the novak 13.5 stock motor with the sintered rotor and was after a safe starting point for rollout. At The track i race at i used to run a 29mm rollout on a co27 . So what would you start at with the B.L
tweak74 is offline
Old 06-22-2007, 06:27 AM
Trader Rating: 38 (100%+)
Locally on carpet I think we were rolling out at 38MM. You will probably need to buy a small spur and some big pinions.
or8ital is offline
Old 06-22-2007, 03:51 PM
Super Moderator
Grizzbob's Avatar
Ummm, REALLY tall. Honestly, you don't need to worry much about a "safe" gearing if you're suing the sintered rotor, I've used some pretty extreme gearings & seen others(including Bob Novak himself) use some INSANE ratios & the motor just keeps chugging along nicely, pulls like a freight train(& I'm talking about FDR's of 3.9:1 with rubber tires at the Novak Race, but I don't know exactly what rollout that equates to, just know the motor can take almost ANYTHING you can dish out).....
Grizzbob is offline
Old 06-22-2007, 03:56 PM
Trader Rating: 17 (100%+)
You can use my Final Drive Ratio and work backward to get your Roll out....we've use this FDR for the main...very much all of us without thermalling problem and the car is almost as fast as 19T brushed car...it is crazy gearing..
I used FDR = 4.5 with sintered rotor, no thermal........without sintered...5.7. Thermal when I was using 5.5 FDR.
Solara is online now
Old 06-22-2007, 05:04 PM
Glowster21's Avatar
Trader Rating: 130 (100%+)
I roll mine out anywhere from 36-41 depending on the layout......
Glowster21 is offline
