Old 04-23-2003, 09:00 AM   #1
davioh's Avatar
Default rubbersealed? acer berrings?
i was wondering if i would need rubber sealed berrings or the acer berings
davioh is offline   Reply With Quote
Old 04-23-2003, 09:27 AM   #2
Lab-driver's Avatar
Rubber sealed bearings are a type of bearing, and Acer bearings are a brand. Why are you buying new bearings, performance upgrade or replacement? Here's some helpful info on bearings.
Rubber sealed: Best used in dirty enviroments because they do a good job of sealing the bearing. It will add some friction however.
Metal shielded bearings: The standard. Good for anything but offroad or very dirty parking lots, etc. Less friction than rubber sealed but more prone to dirt damage.
Teflon shielded: The best in my opinion. Seals well, but with little friction. If you can afford teflon shielded bearings go for it.
Hope this helps.
Lab-driver is offline   Reply With Quote
Old 04-23-2003, 09:30 AM   #3
davioh's Avatar
thanks. guess im not going for rubber berrings...i'll stick with my stock...
Old 04-23-2003, 09:32 AM   #4
davioh's Avatar
oh and also, is there a need to "de oil, re oil" the bearings? i've heard stuff that tamiya bearings are bad...
Old 04-23-2003, 09:48 AM   #5
Speed Demon's Avatar
If you have the budget.. go for the acer pro series ceramic bearing kits... they are superb..
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 04-23-2003, 10:17 AM   #6
university_dave's Avatar
Hope this helps.
You're not comparing like with like there. Shields and seals are not the same thing. A rubber shielded bearing will have just the same friction as one sealed with teflon as the shield does not touch the inner part of the cage like a seal.
Davioh, the Acer ceramic bearings are excellent, I've been running them for a couple of weeks after having removed one seal and flushing all the grease out of them. The run extremely freely and are still as smooth as ever because of the hardness of the balls. They don't come cheap though...
university_dave is offline   Reply With Quote
Old 04-24-2003, 01:49 AM   #7
davioh's Avatar
well they are 129 usd....so much! a bit more and i can get another car! i'll just stick to the ones i have...but how do you do that thing with deoiling and oiling?
Old 04-24-2003, 02:16 AM   #8
Lab-driver's Avatar
university_dave- I wasn't really directly comparing them, just my experiences....
Old 04-24-2003, 08:52 AM   #9
DaveW's Avatar
Davioh, RPM makes a bearing blaster for 8 bucks... and it comes in a variety of colors. Other than that... you need a good can of motor spray... and a light synthetic oil to relube the bearings. Of course... there are all kindsa thoughts on the best lube to use. Just depends on who you talk too. The whole idea is to remove the thick standard grease found in most sealed bearings... and replace it with a long lasting durable oil of less viscosity. Many will remove the seals on one side of the bearing to do this... but it can be tedious and damaging to the race (cage) of the bearing if you arent careful. The RPM bearing blaster is a simple tool and lets you do this without all the added fuss and muss. The reward? A smooooth and seemingly friction free driveline!
- Dave
...you better run like im booger flickin...
DaveW is offline   Reply With Quote
Old 04-24-2003, 10:21 AM   #10
does anyone know if it is posible to buy the acer bearings seperate from a set
jiggamacdaddy is offline   Reply With Quote
Old 04-24-2003, 10:51 AM   #11
Matt Howard's Avatar
If you go to their website you can purchase bearings individually
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 04-24-2003, 12:33 PM   #12
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
yep u can buy them indiv. I have these in my tc3. They are very good, very smooth and very free.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 04-24-2003, 03:39 PM   #13
where online can i find the teflon bearings?
Chris@WeaponR is offline   Reply With Quote
Old 04-24-2003, 03:55 PM   #14
www.bocabearings.com and also www.acerracing.com hope that helped
ACER JRX-S Bearings Formula1fan R/C Items: For Sale/Trade 0 09-18-2006 05:33 PM
Acer Bearings again rcnewb2004 Electric On-Road 15 03-13-2005 06:42 PM
Acer Bearings rcnewb2004 Electric On-Road 1 02-27-2005 05:35 PM
Acer Bearings (which ones?) Skill Electric On-Road 10 02-27-2005 12:40 PM
Acer or Boca? dragoneuh Nitro On-Road 13 10-14-2004 02:21 PM
