Team Orion Vortex Brushless motor >
Old 07-30-2007, 10:01 AM
  #121
rc-zombies's Avatar
Originally Posted by VooDooPH View Post
anybody know the temp range for the 10.5? was running mine the other day all the way down to 5.05fdr with 6-cell nimh and the temp would be only around 145degF. can i gear down more?
thanks!
where are you taking the temp? wire side or pinion side?
on mine.. I'm getting the same temp on the wire side..
on the pinion side it will be alot hotter... I was getting like 180-190+degF.
and did not have any thermal issues..
rc-zombies is offline
Old 07-30-2007, 10:11 AM
  #122
VooDooPH's Avatar
Trader Rating: 18 (100%+)
middle of the can. didn't try taking the temp at the pinion side though. likewis, no thermalling issues as well.
VooDooPH is offline
  #123
i was told by orion techs that the 3.5 vortex has a 190 degree limit, but im sure they quoted me that number to be on the safe side, but anyway im pretty sure all the vortex motors are about the same, so my guess for the 10.5 would also be 190 degrees.
cheech4 is offline
Old 07-30-2007, 10:15 AM
  #124
bmmer701's Avatar
Trader Rating: 17 (100%+)
mine was at 180f no thermal issues. anyone using their vortex with platinum lipo?
bmmer701 is offline
Old 07-30-2007, 10:25 AM
  #125
Joep's Avatar
My 4,5T with LRP TC and 4300 IB's (Rubber / Tarmac) goes up to 149 to max. 175. The last figure only when I pushed very hard.
Joep is offline
Old 07-31-2007, 04:34 PM
  #126
Super Moderator
Marcos.J's Avatar
Trader Rating: 213 (100%+)
here is my orion vortex 4.5 with the novak heat sink , i can gear it to the moon and it never comes off the track over 150 degrees!! with normal gearing is usually around 125-130 degress
Marcos.J is offline
Old 07-31-2007, 10:08 PM
  #127
rc-zombies's Avatar
I advanced the timing to my 10.5 a few degrees.. the car is a rocket.
I used Eagle Racing's new SP motor heatsink and fan....
the fan actually works on the this than the others..
Attached Thumbnails Team Orion Vortex Brushless motor-sp-heatsink-001.jpg   Team Orion Vortex Brushless motor-sp-heatsink-002.jpg   Team Orion Vortex Brushless motor-sp-heatsink-003.jpg
Old 07-31-2007, 10:16 PM
  #128
Nexus Racing's Avatar
Is the Novak heatsink a direct fit?
Nexus Racing is offline
Old 08-01-2007, 06:24 AM
  #129
Super Moderator
Marcos.J's Avatar
almost i had to mill it out about just about .25mm but it works great!!
Marcos.J is offline
Old 08-06-2007, 06:47 PM
  #130
Trader Rating: 26 (100%+)
http://www.racingfactory.fi/shop2/ca...atalog.php?c=5
Can someone please explain the differences you will find in the optional rotors on offer for the GM/ORION Vortex motors.
CountryHick is offline
Old 08-06-2007, 10:28 PM
  #131
Guo Chean's Avatar
the smaller diameter rotor you have the more rpm you will get. but your motor will run less torque than original rotor.
Guo Chean is offline
Old 08-07-2007, 12:33 AM
  #132
yes, personnaly I use a GM 4T with 12.5mm rotor and I have a better feeling than with the 13.5mm.
It gives less dragbrake also.
Oscar told us this weekend at the euro that last batch of his motor swill have smaller diameter rotor inside.
canto54 is offline
Old 08-07-2007, 12:57 AM
  #133
syndr0me's Avatar
Trader Rating: 32 (100%+)
It's interesting they're going in that direction while Novak is moving toward trying larger rotors.
syndr0me is offline
Old 08-07-2007, 12:16 PM
  #134
Guo Chean's Avatar
i think Novak come bigger size rotor is they want their motor runing more efficiency. is not mistake the original rotor size are 12.2mm which is even small than 12.5mm
Old 08-08-2007, 08:29 PM
  #135
barber's Avatar
ok guys i am running a mamba esc & motor i am thinking of using a orion 4.5 bl motor with my mamba esc is it a good mix will it work any ideas.
barber is offline
