Team Orion Vortex Brushless motor >
Old 09-20-2008, 12:27 AM
  #631
RC MARKET's Avatar
Originally Posted by yodace View Post
this magnets suppost to improve performance?
Yes can fine tune your Motor !
detailed info-sheet with tech chart
http://www.teamorion.com/orion/p ... 080918_armature.pdf
& Order here !
http://rcmarket.com.hk/index.php?cPath=72_78
Attached Thumbnails Team Orion Vortex Brushless motor-20080920_24368c69327aa5b6c830jt56xpg0nyxc.jpg
RC MARKET is offline
Old 09-20-2008, 08:12 PM
  #632
xtrememadness's Avatar
anyone know the timing on the vortex 17.5 from the factory. im running against speedpassions and i know that motor is about 13-15 degrees fixed. so if my timing mark is in the middle what is the timing around? i know each mark is 3.6 degrees. thanx
xtrememadness is offline
Old 09-21-2008, 01:40 AM
  #633
Hey Im running a Vortex 2008 3.5T brushless motor and I'm having problems with it, Im running Foam Tyres,Cyclone Tc,5 cell, And a Novak GTB.
It is really slow(slower than a 7.5), and no matter what i do with the gearing or timing it goes slow and/or overheats either the esc or motor. Any body got some ideas.
savageguy is offline
Old 09-21-2008, 11:29 AM
  #634
RC MARKET's Avatar
Test 12.5mm 5mm Hi Torque Armature !
Old 09-21-2008, 01:58 PM
  #635
RC MARKET's Avatar
Hara used Vortex Motor ready to JMRCA
Old 09-22-2008, 12:19 AM
  #636
RC MARKET's Avatar
Old 09-23-2008, 02:36 PM
  #637
has it been fully confirmed yet whether these new rotors cant fit in the older vortex motors & why? all you would need to do, since these new rotors have a bigger diameter shaft where the bearings sit, a bigger ID bearing, 3/16" (4.7mm) x 3/8". im sure it'd fit, even with the new vortex motor being shorter, im sure with a bit of patient you could get one to fit snuggly!
I plan to buy one of these new rotors, try to fit it to my old vortex, if it dont work out, i was planning to get a new vortex motor anyway!
Drift Demon is offline
Old 09-23-2008, 03:41 PM
  #638
I'm sure it is possible to make them fit the older motors (if you are prepared to do enough machining modifications), but surely it would be easier to just fit either a Speed Passion or GM rotor - which are a direct fit into the older Orion motor.
MattW is offline
Old 09-24-2008, 07:42 PM
  #639
BLUE 2's Avatar
Trader Rating: 23 (100%+)
Talking
Hi All
Does any one know why the Orion Vortex 17.5 is not on the ROAR motor list ?
See ya
BLUE 2 is offline
Old 09-25-2008, 06:01 AM
  #640
Gidday Guys
Is the 08 Orion 2.5T motor OK for 6 cell or is it only designed for 5 cell.
Pearce is offline
Old 09-25-2008, 08:29 AM
  #641
VooDooPH's Avatar
Trader Rating: 18 (100%+)
wanted to ask if anyone had the proper gearing for the 10.5 and 13.5 on 1/12 4-cell?
VooDooPH is offline
Old 09-25-2008, 09:21 AM
  #642
Mitch Sy's Avatar
Trader Rating: 8 (90%+)
+1
Mitch Sy is offline
Old 09-25-2008, 11:38 AM
  #643
cyclone speed's Avatar
hi guys , was wondering if the 3.5 motor is faster then any other BL motors .
Does the 2008 version has an advantage compared to the olds vortex, i heard that it had some failures.
Do you guys run a heatsink with a fan on it with 5 cell 3.5. What gearing do you have.
cyclone speed is offline
Old 09-25-2008, 11:52 AM
  #644
RC MARKET's Avatar
Old ver. need change 12-12.5mm armature get more rpm,
but new type too more rpm lose some torque,
so need option new magnet armatures for fine turn your motor o Ultra RPM or Ultra Torque Type !
& with lightweight 10g , size shorter so rolling motor endbell don't have touch road
Old 09-26-2008, 08:21 AM
  #645
Like RCMARKET said, the new motor seems to have more rpm and a litle less torque and less consumption.
Also, less weight and shorter, so easier to balance the chassis.
IMO, easier to drive and just as fast.
Itchy is offline
