Team Orion Vortex Brushless motor >
Old 04-26-2007, 10:51 AM
  #31
Rick Hohwart's Avatar
Originally Posted by pitipotinou
HI!
which is the timming to be put with orion vortex 4.5 and LRP 2007 speedo ??
more timming or not ?
Use the neutral factory timing setting that comes with the motor.
Rick Hohwart is offline
Old 05-05-2007, 12:46 PM
  #32
neosan's Avatar
Hi all,
Anyone is running mamba speedo with Vortex 3.5?
Is there any kind of problem to run Mamba speedo with Vortex 3.5?
thanks a lot
neosan is offline
Old 05-08-2007, 02:34 PM
  #33
Joep's Avatar
Originally Posted by Joep
In about 3 weeks I'm going to test the 4,5T vortex with the LRP Sphere TC.
A race mate of my had a broken motor and used my Vortex 4,5T with the LRP 2007 TC. It was during a race so it was not really a test but more a gamble. We used a little higher FDR then we use for the LRP 4,5T and the motor had a little more punch but the topspeed was lower. We both think that we have to go lower with the FDR, but we had no opppertunity to test that.
End this month we try it again.
Joep is offline
Old 05-11-2007, 11:09 PM
  #34
secretsg's Avatar
Nitpicking here but....... no decals in the package? I realize there's not sensor wire but not even a decal on a $100 motor?
secretsg is offline
Old 05-11-2007, 11:14 PM
  #35
are the peak vantage BL's the same motors as these? and how weoll will these motors (vortex/vantage) work with the mamba max?
myk505 is offline
Old 06-03-2007, 09:43 PM
  #36
They definitely seem to run cooler than the Novak.
sf85 is offline
Old 06-03-2007, 10:09 PM
  #37
Wing Chun's Avatar
Hi Guy's
Can anyone please help me
What model Orion Brushless would give me the same power as a Orion OJ 7x1 Modified motor. also if I am running a ratio of 8.41 FDR for my track now, what changes in the ratio would I need to do.
I run a Cyclone Andy moore-speed model
final ratio 2.4375.1
I run 64 pitch and use a spur 108/ pinion 31
Thanks Addam
Wing Chun is offline
Old 06-03-2007, 10:23 PM
  #38
Super Moderator
Marcos.J's Avatar
Trader Rating: 213 (100%+)
Originally Posted by Wing Chun View Post
Hi Guy's
Thanks Addam
the 3.5
here are the recommended ratios
Marcos.J is offline
Old 06-04-2007, 01:53 AM
  #39
Wing Chun's Avatar
Thanks Marcos
Regard's
Addam
Old 06-04-2007, 11:55 AM
  #40
Super Moderator
Marcos.J's Avatar
Thanks Marcos
Regard's
Addam
no problem
Marcos.J is offline
Old 06-22-2007, 07:28 PM
  #41
Trader Rating: 206 (100%+)
Nice that the new 10.5 does not come with an updated FDR chart.
Any ideas as to the FDR for rubber tire large track?
dodgeguy is offline
Old 06-22-2007, 08:09 PM
  #42
Super Moderator
Marcos.J's Avatar
6 cells 5.0 fdr 5 cells 4.5FDR
Marcos.J is offline
Old 06-22-2007, 08:24 PM
  #43
Have you ran this motor yet Marcos? How does it compare to the novak 10.5ss?
dodgeguy is offline
Old 06-22-2007, 08:31 PM
  #44
Super Moderator
Marcos.J's Avatar
its pretty good i think the novak has a little more RPM but the orion can pull a higher gear my motor was coming off the track around 140 degrees and with 5 cells it came off the track around 117 degrees,plus 5 cells believe it or not was faster than 6
Marcos.J is offline
Old 06-22-2007, 09:11 PM
  #45
Have you tried to increase the timing to increase RPM?
dodgeguy is offline
