Team Orion Vortex Brushless motor >
Old 12-16-2007, 07:21 AM
  #376
Born2Run's Avatar
Originally Posted by K_King View Post
Hey guys quick question about my 7.5........
It seems like its "Dead." Now Ive never run a BL motor before, and in my T4 it has really no punch at all, I would say its around the same speed as my 19T as well. Its a Brand New Motor, so Im not worried about it being messed up, but it just doesnt seem right to me, unless a 7.5 just isnt that fast.
My other question is that when I slow down it has super locking brakes, the other thing is that sometimes I hear a clicking sound, as if its skipping on the spur/pinion, but the mesh is fine. Its obviously not like a brushed motor, so Im trying to figure BL out so far.
What speedo you use? Have you checked it if everything is OK with?Have you calibrate the esc with your radio? Have you checked your speedo-motor connection? Is it hardwired or you use some kind of connectors?
Born2Run is offline
Old 12-16-2007, 07:42 AM
  #377
Born2Run's Avatar
Anyone running a turing car with Vortex 4.5T & Mamba max esc?
Born2Run is offline
Old 12-16-2007, 08:16 AM
  #378
K_King's Avatar
Trader Rating: 47 (100%+)
Im running a GTB Spectrum with an M11. The wire is an Orion wire and its new as well. Hardwired straight to the motor. ESC was calibrated as well.
K_King is offline
Old 12-16-2007, 09:22 AM
  #379
Super Moderator
Marcos.J's Avatar
Trader Rating: 213 (100%+)
wyd runs the mamba with the vortex motor
Marcos.J is offline
Old 12-16-2007, 09:45 AM
  #380
Born2Run's Avatar
I would like to know what FDR are running with the 4.5T.
Born2Run is offline
Old 12-16-2007, 01:24 PM
  #381
Super Moderator
Marcos.J's Avatar
Marcos.J is offline
Old 12-17-2007, 01:29 PM
  #382
Thistle's Avatar
Originally Posted by Quante View Post
My guess is simply does not spin... When someone's sensors are damaged, the motor usually cogs. I'm not sure, but does the sphere work when the sensor wire isnt attached?
I'm going with your positive connector- top deck theory, but how does your positive connector hit the top deck when its hooked up to the battery?
Did the sparks come from within the motor? Open it up, look for burn marks or a burny smell. That'll tell you if its fried.
The sparks and smoke came from the motor... and it's the motor that smells burnt. The way the battery was mounted, the terminals were at the rear of the car... the positive was close to the top-deck.
I've examined the top deck, and there are no burn marks where the terminal may have touched the top-deck.
Thistle is offline
Old 12-23-2007, 05:28 PM
  #383
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Why wont my motor work when I try to run it in reverse?
at 0 timing, it works fine going normal (in my TC car) But for my off road car I had to flip 2 wires, and it makes a weird sound, and spins slow, with a novak, and orion motor it did the same thing
Im using a LRP TC sphere, do I have to re-program my esc, or whats wrong?
BlackedOutREVO is offline
Old 12-23-2007, 05:36 PM
  #384
Check that the motor screws aren´t too long, they will touch the fan inside the motor if they are.
Mr_Orange is offline
Old 12-23-2007, 05:39 PM
  #385
Flipping the wires only works with sensorless. The TC-spec doesnt have reverse in the software but the GTB do.
Old 12-23-2007, 06:41 PM
  #386
RC MARKET's Avatar
All Bl motor change small size rotor have more RPM !
was arrived Orion 2.5T , 3T & 4T
RC MARKET is offline
Old 12-23-2007, 07:08 PM
  #387
Im not buying a GTB...... I was just going to run it till my BL system comes for it...
Old 12-23-2007, 07:32 PM
  #388
syndr0me's Avatar
Trader Rating: 32 (100%+)
How big is the rotor now? 12mm?
syndr0me is offline
Old 12-23-2007, 09:04 PM
  #389
RC MARKET's Avatar
sorry not have open !
Old 12-23-2007, 09:05 PM
  #390
RC MARKET's Avatar
Tekin R1 & R1 Pro was arrived ,
can use 2.5T , 3T & 4T ...
www.rcmarket.com.hk
