Old 12-02-2001, 08:46 AM   #16
Trader Rating: 49 (100%+)
I can't get the guys at protrak to email me back. And I really don't want to call since they are in the UK.
Anyone had an luck talking with them via email?
rodneybarrett is offline   Reply With Quote
Old 12-02-2001, 09:10 AM   #17
dtm
dtm's Avatar
Send a message via ICQ to dtm
Phil has been very helpful solving my display problem via email.
dtm is offline   Reply With Quote
Old 12-02-2001, 11:30 AM   #18
Corse-R's Avatar
Originally posted by xray
Corse-R,
For competition, which charger has more punch and power?
The schulze, gave sufficient punch to my Panas SMH. In fact, we've conduct one objective test with several chargers: Novak Millenium, Schulze Eco Select, Yokomo YZ-720P and a Turbo35 BL.
Every charger peaked one empty Pana SMH (First charge) at 5.0Amps. The results were quite interesting.
Yokomo, gave highest voltage (Compared with a separate DMM), peaking the Panas a 9.78A and being the coolest (42 C).
Schulze were at pace with the Yoko. Peaking a 9.64v and 41 C. With this charger you can charge by Peak and temp charge at the same time, very interesting.
Later was the T35 and the Novak charger.
After this, every pack was discharged at 30A with the discharge function of the T35 and taked note about the seconds and the Av. Voltage, cutting at 6.0v.
Yokomo gave the max. Av. voltage.
Schulze gave the best between discharge time and av. voltage.
T35 gave the best discharge time with a lesser av. voltage.
Novak was the 'worst'.
This test was done with 4 Reedy #624 packs with this characteristics: 1.130v or better (1.132v max), 352 - 353 secs and I/R of the cells with 18 to 20 (My best 4 packs).
With this test I choosed the Schulze. You can go wrong. But a word of caution. Has a feature that cannot be switched off: After peaking, the pack goes into trickle charge mode.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 12-02-2001, 07:42 PM   #19
xray's Avatar
Daniz24,
Corse-R has conducted a test on few charger on the market. he mentioned Yokomo YZ-720P, What's the diffrence compare to BMS & BCS?
xray is offline   Reply With Quote
Old 12-02-2001, 09:57 PM   #20
Regional Moderator
daniz24's Avatar
Daniz24,
YZ-720P is the older version from Yokomo. the newest charger are BMS and BCS Double.. (both now has Yokomo charge feature)
daniz24 is offline   Reply With Quote
Old 12-02-2001, 10:09 PM   #21
xray's Avatar
Can you charge 2 pack at the same time??
Old 12-02-2001, 10:23 PM   #22
Regional Moderator
daniz24's Avatar
only the BCS Double can answer your question
Old 12-03-2001, 07:36 AM   #23
MissX's Avatar
I think all those three chargers have their own plus and minus if compared. But don't forget you have to compare apple to apple.
I have seen good drivers only using Novak Millenium and won the race.
But if money is no object, I would buy two Schulze.
MissX is offline   Reply With Quote
Old 12-03-2001, 05:45 PM   #24
Mad Max's Avatar
The charger is key for the 1-3% extra advantage needed at the nationals, worlds. If you drop the bucks for the cells and the charger (I can see my loan officer smiling), then don't have the driving skills, why bother. If you can keep the car between the dots and are top 2 or 3 but just seem to can't beat the local, then you need those pieces.
I watch certain racers that are the torment of all with new stuff week in and week out. But they are also not having to deal with a misses or are related to bill gates. Most of the hot shoes in So Cal will whip you with their year old stuff and tell you the reason is between the ears and the fingers.
Now go buy the damn Schutze and enjoy.
PS I use a Victor Sr. (10 years old) and I have some of the faster cars in class (It aint the charger and it aint just the driver).
Mad Max is offline   Reply With Quote
Old 12-03-2001, 06:44 PM   #25
Moderator
Speedo's Avatar
R/C Tech Charter Subscriber
IMO, the Millenium, Tekin etc. will charge just as well as the T35, Pro-trak etc. Just the more expensive chargers have more features. They all charge the same, you won't notice a difference there, but you can't run a motor off a Tekin
Speedo is offline   Reply With Quote
Old 12-03-2001, 06:52 PM   #26
MissX's Avatar
Some racers experienced a difference in punch and runtime over different chargers. But again at a certain price range the difference is getting very small. I like what Mad Max said about using a 10 year old charger. This really intimidate the others
Old 12-03-2001, 06:53 PM   #27
Send a message via AIM to Ovalman19
Just because a pack peaks higher doesn't mean it is better. that usually means it is worse, higher internals.
Ovalman19 is offline   Reply With Quote
Old 12-03-2001, 07:24 PM   #28
Corse-R's Avatar
This can sould a little sillyness, but a higher peak voltage (and, as you said a little higherI/R), many times can signify a complete dump of the battery or finishing the main with the cells weak, but not dumped.
Sometimes is interesting.
Cheers,
Corse-R
Old 12-03-2001, 09:55 PM   #29
Moderator
Speedo's Avatar
A higher peack voltage ususally signifies higher IR. This effectively gives the pack less punch, and less run-time.
Old 12-04-2001, 01:23 AM   #30
Then what can we do if the pack peaks at a higher voltage? Can any of the three chargers 'recondition' them?
rcethilon is offline   Reply With Quote
Can turbo 35BL charger batt higher than 3300mah? agp Electric On-Road 4 11-09-2006 05:36 PM
[WTB] CE Turbo 35BL or Stealth Charger squarehead R/C Items: Wanted to Buy 3 08-12-2005 03:56 AM
Turbo 35BL charger w/ free batt Northerner R/C Items: For Sale/Trade 3 01-19-2003 09:29 PM
Competition Electronics TURBO 35BL Stealth charger for sale Ron Meloni R/C Items: For Sale/Trade 2 01-06-2003 08:33 AM
Turbo 35bl Charger moceanrc R/C Items: For Sale/Trade 0 07-16-2002 09:16 PM
