Old 04-22-2003, 09:26 AM   #1
lonestar1127's Avatar
Talking Servos
wat is the best servo now??
lonestar1127 is offline   Reply With Quote
Old 04-22-2003, 09:31 AM   #2
Send a message via Yahoo to ZigZagRC
JR 4750!! i think that is the best servo out for the money, and they have great customer service, i sent one in that the motor burnt up in, and they sent me a brand new one for free! thats why i will always use JR servos
~ZigZag
ZigZagRC is offline   Reply With Quote
Old 04-22-2003, 10:51 AM   #3
CRASH's Avatar
Trader Rating: 26 (100%+)
JR Z4750 are awesome. They are in all of my cars, nitro and electric. I have one friend though that swears by Aitronics 94357s and 94358s. A little bit more money but exceptional servos as well.
The new JR Digital Servos are quite awesome as well.
Later,
CRASH is offline   Reply With Quote
Old 04-22-2003, 12:21 PM   #4
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Default Re: Servos
Originally posted by lonestar1127
what is the best servo now??
Well there are several it Just matters which one has the Speed and torque you would want ..
Ko 2123 & 2143 both very good
Futaba 9550 & 9451 also very good
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 04-22-2003, 12:27 PM   #5
NTC3NUT's Avatar
I've had good luck with Airtronics 94357 & 94737 (?), I think those numbers are right. But I have been the happiest with my Futabas, S9402/9450/9451/9550. All of these have been excellent. I hear the JR & KO digitals are good too. I don't think you'd go wrong with anything from anyone of these manufacturers.
NTC3NUT is offline   Reply With Quote
Old 04-22-2003, 02:42 PM   #6
Cole Trickle's Avatar
The fastest one I've found so far, is the KO Propo PDS-2123; 0,06 sec/60 deg., 9,5 kg torque, digital, coreless, metal gear and double bearings.
The only one I've that is faster, is the discontinued KO PS-2015, which is 0,05 sec / 60 deg. But it's analog and with plastic gears.
If we're talking best servo for a given budget, it's another story.
I will say, buy the best you can afford.
Please note, that several ESC's only deliver 5 volt through the BEC. That means a 6 volt servo, will be 25% slower. If you got such a ESC, I suggest you consider getting a servo with 7,2 volt FET wire, alternatively upgrade the ESC.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 04-22-2003, 08:24 PM   #7
thanx alot guys
Old 04-22-2003, 08:35 PM   #8
popsracer's Avatar
Default Servos
~ZigZag
I've also had the same experience with JR. 2 of my DZ-8550's failed and they replaced them with brand new servo's.
On the other hand, my Hitec (5)625 servos have been in numorous times and only get repaired. The warranty is just about up so it's the circular file next time. (I did get a new servo lead)
I'll probably replace the Hitec's with JR 4780's.
popsracer is offline   Reply With Quote
Old 04-22-2003, 08:43 PM   #9
psycho's Avatar
KO PDS2143 gets my vote. I have them in all of my cars.
psycho is offline   Reply With Quote
Old 04-23-2003, 11:35 PM   #10
are all tis compatible to airtronics rx?
Old 04-24-2003, 02:16 PM   #11
Suspended
It should be.
R C king is offline   Reply With Quote
Old 07-11-2003, 10:28 PM   #12
wrxmy99's Avatar
I have just that...digital servo with NO FET wire, Futaba HRS receiver and a Quantum Pro Sport that puts out 5v but HAS a FET wire.
Is there anything I can do? eg replace the +ve wire on the ESC connection to the servo with the FET wire? My HRS receiver can run on 6 or 7.2 volts...
HELP!!!
Andy
wrxmy99 is offline   Reply With Quote
Old 07-12-2003, 12:45 AM   #13
Send a message via AIM to Johnnytc3
futabas 9450s and 9451s, never had a problem soo smooth .... stay away from hitec
Johnnytc3 is offline   Reply With Quote
Old 07-12-2003, 03:17 AM   #14
wrxmy99's Avatar
How do you hook the 9451 to hi volts? or dont you need to? just run it of the 5v BEC?
Old 07-12-2003, 12:36 PM   #15
If you need it or not? Well, personally I believe that a steering servo cant be too fast - at least not if the driver is immitediate or above. But some people do fine with mid-range servos, so it might just be me.
I dont think you want to throw in 4 1,5 volt cells?
If you put the red wire on the servo to the mainbatt 7,2 volt, it'll turn your sweet servo into smoke... maybe not at first, but for sure after a while....
Now, I dont know your reciever, if it has a nice BEC with 6 volt output, there might be a work around. Tell me if your RX do have a built in BEC and what the voltage is. Preferable with some good amps specs too. If so, I can explain the workaround for you.
FS- High end radio gear, KO Helios, KO servos, JR servos, Spektrum cdelong R/C Items: For Sale/Trade 16 11-01-2007 09:33 PM
Servos Craig1 Australia For Sale/Trade 0 02-20-2007 04:20 AM
LOT OF SERVOS; Futaba,Traxxas & mini servos! nitro468 R/C Items: For Sale/Trade 10 03-27-2006 07:19 PM
jr,kopropo,futaba servos (high speed/trorque sedan servos) lazyboy R/C Items: Wanted to Buy 6 06-06-2005 11:27 AM
NTC 3 Servos martymarine Nitro On-Road 1 09-03-2003 10:06 PM
