4tec high speed help >
Old 06-17-2007, 06:02 PM
I am newer to the onroad world and I have a 4tec with a novak brushless gtb w/4.5r motor. It runs in the car great for only about half or a little more throttle when I go to give it any more it cant keep a straight line it is always pulling I think to the same side, not sure what to do to even it out
Help
watches101 is offline
Old 06-17-2007, 07:43 PM
peded's Avatar
Did you check the tweak on it?
peded is offline
Old 06-17-2007, 08:13 PM
Joel Lagace's Avatar
you got lots of horsepower on a less then perfect chassis. Check tweak and weight balance. Also what tires do u use? IF your using kit included tires that will be a problem with the big motor your runing
Joel Lagace is offline
Old 06-19-2007, 09:43 PM
yes I am useing the stock rubbers I have been thinking about getting some new foams that is what i was told works best by my local store
this may sound dumb but what is tweak?
and what is a good way to even out my weight?
I wanna be able to control this guy
Thanks!
Old 06-19-2007, 09:57 PM
Here's a good article on tweak.....
http://www.rc411.com/pages/howto.php?howto=2&page=1
Whatchamacallit is offline
Old 06-20-2007, 12:20 AM
nice article, helps a lot I hope, I will try it out
