Old 04-21-2003, 11:24 PM   #1
warlord385's Avatar
Default 1/10 sedan modified of 1/12 scale stock
I usually race in the 1/10 stock sedan. i'm an okay driver and was wondering what type of racing would help improve my skills more 1/12 stock or 1/10 modified. Here is a link to the local track www.capitolcityrc.com
warlord385 is offline   Reply With Quote
Old 04-22-2003, 12:19 AM   #2
fatdoggy's Avatar
R/C Tech Charter Subscriber
1/12th racing will make you a better driver because there so bloddy fast and you need to drive very precisly and consistently to do well, you can then carry those skills back to TC. The track dosn't look all that big and it looks very tecniqual(sp?) so I'd say 1/12th.
fatdoggy is offline   Reply With Quote
Old 04-22-2003, 12:35 AM   #3
warlord385's Avatar
wuts sp? U think i should use p2k2 or monster in 1/10 or 1/12
Old 04-22-2003, 05:23 AM   #4
sosidge's Avatar
sp = "did I spell that right?" - "Technical" is the answer, just in case you were wondering fatdoggy!
Monster is probably a better 12th stock, you don't need the torque of a p2k2.
Old 04-22-2003, 09:38 AM   #5
fatdoggy's Avatar
Old 04-22-2003, 02:32 PM   #6
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
I'd say 1/12th scale stock because it will make you a better driver and quite a bit easier to drive and maintain than touring mod. If you don't have really quick reflexes and good lines, mod will really frustrate you on a small track. On a side note, touring mod sure is a lot of fun
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 04-22-2003, 03:48 PM   #7
tufferwilde's Avatar
Well - look at it this way... to run 12th scale... you will need all new gear - batteries, servo, tires... etc...
If you run Mod TC - chances are that you will only need a motor...
Mod TC is fun... setup on the car becomes very important... 12th scales require alot of maint...
Wilde
Trackside Hobbies and Raceway: www.tracksideraceway.com
Novak Electronics: www.teamnovak.com
tufferwilde is offline   Reply With Quote
Old 04-22-2003, 04:01 PM   #8
Tuffer, that is true, but for TC mod you go through batteries quicker, you need to buy A LOT more brushes, and you replace armatures quicker. You're also right about the setup stuff, the faster you go the more noticeable the changes you make are and the handling traits become apparent, so you need better setups. What i meant by maintinance was rebuilding your motor practically every run mainly. But you're right about 12th maintinance, you gotta tweak 'em every run, but if you dont hit stuff it usually isn't too bad Warlord385, you said "i'm an okay driver" so i'd just recommend getting into 12th scale stock because it'll make you a better driver and then Touring Mod will be more fun because you will be able to drive it better
USVTA Member #211
Best Sedan For Stock FLCL Electric On-Road 30 08-25-2006 10:36 AM
.21 stock or .21 modified motomanpat Electric Off-Road 9 06-21-2006 05:24 AM
Stock Or Modified? igkyoa Electric Off-Road 1 08-30-2003 12:43 PM
stock v. modified davioh Electric On-Road 8 04-01-2003 11:24 PM
Stock to Modified comparison Aurra Sing Electric On-Road 7 10-18-2001 09:56 PM
