MOTOR HELP PLEASE >
MOTOR HELP PLEASE
MOTOR HELP PLEASE
Old 06-16-2007, 06:01 PM
16skyline's Avatar
Default MOTOR HELP PLEASE
I have a 8x1 motor that I am having trouble with.
When power is connected to the motor it will not go until you give the armature a little turn then it is away until the motor stops then it won't fire back up until the armature is turned again. The comm has been cut with a new lathe bit and it has new brushes installed.
Can someone help me please.
16skyline is offline
Old 06-16-2007, 06:54 PM
andrewdoherty's Avatar
Trader Rating: 47 (100%+)
sounds like a hung brush. Check to see that the brushes move freely in the hoods. Also check the bearing to see that it is not bound up.
andrewdoherty is offline
Old 06-16-2007, 06:58 PM
whoopass's Avatar
Ditto, sounds like the brush spring is hung up on the hood or the brush braid. try pinging the brush, so the brush will make proper contact with the comm.
whoopass is offline
Old 06-16-2007, 07:19 PM
Check timing, might be way off.
Manning is offline
Old 06-16-2007, 09:16 PM
16skyline's Avatar
I have got the motor working it was the wire on the armature not connecting, but now it is working the motor is running in reverse, but the red wire is to the postive and black to the negative going by the postive mark on the motor, any ideas?
Old 06-16-2007, 09:29 PM
ALBERTO's Avatar
Trader Rating: 23 (96%+)
spin the end bell 180 deg...
ALBERTO is offline
