Duratrax Ice Charger >
Old 06-12-2007, 02:45 PM
barber's Avatar
Could any one give me some feedback on the four step mode the ice has,is any one using it,is there a difference in run time and punch when used.
if so any adjustments for a ib4200mah.
barber is offline
Old 06-12-2007, 03:37 PM
Trader Rating: 38 (100%+)
I think I noticed more punch when I used it. I charged my batteries quicker and cooler using the 4-step mode.
For IB3800s, I used a program like this
Step 1 to 800mah I charge at 2.5 amps
Step 2 to 3800mah I charge at 6.5 amps
Step 3 to 4100mah I charge at 4.5 amps
Step 4 to 4800mah I charge at 2.5 amps
Much of the time, my IB3800s get to 4400mahs before it peaks. I always discharge and balance my pack before I 4-step though.
You can choose your own 4 step options too. Just remember to start your charge slow to get the pack ready for intense charging. Then adjust your 2nd step for as long as you want to charge at that rate for, then slowly ramp it down to finish the charge. My packs rarely get over 100F ever when charging. The only time they do get over 100F is when I don't balance or deep discharge them for too long.
mattnin is offline
Old 06-12-2007, 04:31 PM
barber's Avatar
discharging question
do u discharge them right to 0 or to 0.9
barber is offline
Old 06-12-2007, 05:40 PM
I use the tekin battery doctor, so I think that discharges each cell to .5V
mattnin is offline
Old 06-12-2007, 06:53 PM
barber's Avatar
Thumbs up thanks
thanks for the info
barber is offline
