Old 06-12-2007, 02:45 AM   #1
Default Cleaning Bearings
Hey fellas,
I've got t1fk05 that i havn't used since christmas. The time has come to get back to the track. Just wanted to know what's the best way to clean and oil the bearings for it?
Many thanks,
Gizmo.
~AR~ Gizmo is offline   Reply With Quote
Old 06-12-2007, 03:11 AM   #2
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
for metal shielded bearings i use a needle or pin to pry out the thin metal lock ring on both sides of the bearing. with the lock ring and the metal shields removed, i dunk the bearing in a film can half filed with cleaner spray, cover it then shake it like you would a margarita. after shaking, take the bearings out, place them on a paper towel, oil them up then place the metal shielding and the lock ring back.
VooDooPH is offline   Reply With Quote
Old 06-12-2007, 03:30 AM   #3
Thanks for the info VooDooPH. My bearings have blue rubber seals through. Will that make a difference?
Old 06-12-2007, 03:37 AM   #4
Xray To The Max's Avatar
I use an ultra-sonic cleaner, put your bearings in the metho or kero in the ultrasonic cleaner and all the grit will come out of the bearing.
Ryan Maker - Team Xray - Hudy - Speed Passion - Ko Propo - Ryan Dezign.
Xray To The Max is offline   Reply With Quote
Old 06-12-2007, 03:39 AM   #5
VooDooPH's Avatar
not so sure how to remove the covers on a rubber shielded bearing. you can try prying them off with a needle though (be gentle though so you don't break it). but everything else should be the same in terms of cleaning it.
Old 06-12-2007, 04:04 AM   #6
Kanea6's Avatar
Trader Rating: 7 (89%+)
Xray To The Max where did you get that ultra-sonic cleaner
Xray RX8 - OS Engines, VP Fuels, Matrix Tyres, KO Propo
Xray NT1 - Novarossi, VP Fuels, Matrix Tyres, KO Propo
Xray X12- Hobbywing, Thunder Power, Much More, KO Propo, Hudy
Kanea6 is offline   Reply With Quote
Old 06-12-2007, 04:21 AM   #7
I would use a ultra sonic cleaner. I've had mine for years. Just put your cleaning agent in and turn it on.You don't have to mess with the seals- all the grit will come out. Dry them out and spin them to see if they are worn out. Reoil and they are ready to go.I also use the USC to re oil the bearings with Marvel Mystery oil the same way.
I got my stainless steam tub cleaner I think I ordered it from a jewelry store many years ago. I did try one of those cheap plastic jobs - only the plastic melted with the cleaning agent.
Team Epic/Trinity -Michael Bruce Hobbies-Team CRC ,Kimbrough Products and GForce.
WGT-R, GT-12 Racing USA (21.5 ), Formula 1 and Home Track is 386 RaceWay,ROAR #7540.
BullFrog is offline   Reply With Quote
Old 06-12-2007, 05:56 AM   #8
KyLayfield's Avatar
Trader Rating: 86 (99%+)
http://www.axiommotors.com/indi-sparkle-p-171.html
KyLayfield is offline   Reply With Quote
Old 06-12-2007, 06:08 AM   #9
Scottrik's Avatar
Trader Rating: 245 (100%+)
Harbor Freight has quite a selection of ultrasonic cleaners. Even the $30 one indicates it has a stainless steel tank. All run on household current rather than a couple of AA batteries...
http://search.harborfreight.com/cpis...ord=Ultrasonic
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 06-12-2007, 11:25 AM   #10
mtveten's Avatar
Trader Rating: 27 (100%+)
For those cleaning the USC way what solvet do you use? I picked up one of the harbor freight jobs and denatured alcohol, it cleaned well enough but I still had to remove the seals to let get all the grit out.
Mark
mtveten is offline   Reply With Quote
Old 06-12-2007, 01:57 PM   #11
Spray your bearings with brake cleaner or CO-Contact Cleaner.
savageguy is offline   Reply With Quote
Old 06-13-2007, 05:54 AM   #12
Trader Rating: 61 (100%+)
INDI Sparkle - Bearing and Parts Cleaner
http://nexusracing.net/product_info....9bb1c9ce1ffd8d
fav0re is offline   Reply With Quote
Old 06-13-2007, 07:28 AM   #13
NOOB-SMOKE's Avatar
Default bearings
On the xray bearings its virtually impossible to get the blue shim out without stuffing it.Get it out and leave 1 side out for good.
Then put it on a pen and spin it with your finger and spray with motor spray then re oil it.
cheers!!
NOOB-SMOKE is offline   Reply With Quote
Car cleaning and bearings. simon_allen Electric On-Road 6 03-07-2007 08:29 AM
Cleaning bearings offroader Electric On-Road 18 08-28-2006 08:25 PM
Car Cleaning, Bearings? Fervidsea Electric On-Road 11 02-08-2006 04:43 PM
cleaning bearings pro4racer Electric On-Road 8 07-17-2005 10:45 AM
Cleaning Bearings mtc3od Electric On-Road 12 11-18-2004 10:00 AM
