Old 07-15-2007, 09:52 PM   #61
rctouringracer's Avatar
Send a message via Yahoo to rctouringracer
Try removing all the droop in your suspension, stiffening the front suspension, and lowering the ride height as much as possible, plus if you haven't installed the 2 degree rear toe carriers I would suggest doing that first.
I have tried the different tire combinations and had minumal success with that.
The most important thing is throttle control.
rctouringracer is offline   Reply With Quote
Old 07-20-2007, 01:46 PM   #62
madjack's Avatar
Trader Rating: 20 (100%+)
Send a message via Yahoo to madjack
Bueller?... Bueller?... Bueller?
madjack is offline   Reply With Quote
Old 08-27-2007, 10:20 PM   #63
Trader Rating: 18 (100%+)
Send a message via Yahoo to infanterene
I love my M04. I have the alfa gtv. Are there any other forum that are more active for m03-4?
RC America - Team X-Ray - Maxys Fuel
infanterene is offline   Reply With Quote
Old 08-27-2007, 10:37 PM   #64
sportsracer-5's Avatar
There's a very active Mini thread on here:
http://www.rctech.net/forum/showthread.php?t=20068
sportsracer-5 is offline   Reply With Quote
Old 01-27-2009, 05:38 PM   #65
megasos's Avatar
Hi!
Sorry for my english cause i'm from russia.
So i have a trouble with my M04-M with Alfa Romeo Giulia Sprint GTA body. In the turns front steering wheels get a friction with the side panels. I need to move the body some forward. How can i do that?
1/18 Team Losi Mini-LST
1/10 Tamiya Toyota Tundra High-Lift
1/10 Tamiya Lancia Delta TT-01
1/10 Tamiya Alfa Romeo Giulia Sprint GTA M-04M under construction
megasos is offline   Reply With Quote
Old 01-27-2009, 05:51 PM   #66
Scottrik's Avatar
Trader Rating: 245 (100%+)
WOW!! Here's a thread back from the dead!
Was your body pre-drilled with your Alfa kit? If so, you shouldn't need to move the body fore or aft (front or back). You likely need to move your body up one more hole on the posts. I know if I get the body RIGHT down where it's looking good (though lower than a "real" historic Alfa GTA) the front and rear tires rub at the tops of the fender wells. Lift the body by a hole and the problem goes away.
Good luck with your M04 adventure...they're neat cars!
Congressmen should wear uniforms like NASCAR drivers so we can identify their corporate sponsors.
THE REVOLUTION WILL NOT BE TELEVISED -Gil Scott-Heron (1949-2011)
Scottrik is offline   Reply With Quote
Old 05-26-2009, 12:12 PM   #67
Mister-E's Avatar
Questions??
M-Chassis revival
Guys, where can you buy the Alfa Giulia body????
Chassis #58307
Many many thanks in advance!!!!
Mister-E is offline   Reply With Quote
Old 05-26-2009, 03:55 PM   #68
Scottrik's Avatar
I'm pretty sure Tamiya have not made the Giulia body available separately so you end up buying a complete kit if you want a body. Think of it as a DAMN expensive body, but one that comes with a VERY comprehensive spares kit. Pick up an aftermarket body for the new chassis (or the old and build the new with the Alfa body) and you'd have a car to share with a friend.
Old 05-27-2009, 05:08 AM   #69
hi, Tamiya does sell the Alfa Giulia body. bought one last year. depends if your local hobby store carries it.
rccartips is offline   Reply With Quote
Old 05-27-2009, 05:49 AM   #70
Peter $'s Avatar
I have a Beetle (M04-L), which I drive on carpet.
My problem is that I'm understeering like crazy, so I really think I need some grip in the front. My only hop-ups are 3 Racing dampers and ball bearings, and so I drive whith the original tires.
Should I go for S-grip tires in the front aswell, or can you suggest other tires (or combination of front/rear tires) that will give me better steering without flipping over (which for me has never happended).
I also driv TC on the track, and have good grip, so I don't think there is anything wrong with the carpet.
I have attached a couple of pictures, just for something to look at
Cheers,
Peter
Peter $ is offline   Reply With Quote
Old 05-28-2009, 02:53 PM   #71
RogerHewson's Avatar
Send a message via AIM to RogerHewson
Default M Chassis 6 Hour Enduro
Tamiya America is hosting a 6 hour M chassis enduro at their Aliso Viejo track on July 18th! Here is the link to the rules, entry forum and details. http://www.tamiyausa.com/articles/fe...article-id=405
RogerHewson is offline   Reply With Quote
Old 09-05-2009, 05:01 AM   #72
PaPeRo's Avatar
Cheers,
Peter
Those have nice paint jobs! Is that a HPI NB Miata body?
Anyway to reduce understeer you could change tires and/or change your spring setup.
TIRES
Option 1: Put higher grip tires on the front and lower grip tires on the back.
Option 2: Put same grip tires front and back
Option 1 will reduce understeer more than option 2. Go with whicever option gives you enough reduction of understeer.
SPRINGS
Option 1: Put soft springs in front and hard in back
Option 2. Put medium springs in front and hard in back
Option 1 will reduce understeer more than option 2. Go with whichever option gives you enough reduction of understeer.
Finally you can combine both tires and spring options together to get even higher reduction of understeer. For example put super grip tires and soft springs in front and medium grip tires with hard springs in back.
PaPeRo is offline   Reply With Quote
Old 12-23-2009, 07:37 AM   #73
Default my m chassis...m04
tranz1978 is offline   Reply With Quote
Old 12-23-2009, 08:17 AM   #74
Default more pics
Old 12-23-2009, 05:38 PM   #75
tranz1978, wow! so realistic. join us in our m-chassis club races at jp raceway. M04 is the best. Too bad Tamiya is not producing newer M04s.
ps1 track... good memories.
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
Selling Schumacher Mi2, Tamiya M02, Tamiya TA04-S, Tamiya TB Evolution 3 Surikarn Ltd st_rob Australia For Sale/Trade 4 12-23-2008 07:37 PM
Tamiya 415 MSX, legacy 2.0, NIP Type A tires, Tamiya towel for sale or trade Fastburn R/C Items: For Sale/Trade 16 09-06-2008 12:45 AM
FS: Tekin Rebel 2 ESC w/ Tamiya GT Tuned Motor & Tamiya AM Radio & Receiver wrxnfx R/C Items: For Sale/Trade 6 06-10-2008 06:40 PM
Tamiya M03 / Trinity Brushes / Muchmore Battery Cooler / Tamiya M Chassis Wheels bluejays R/C Items: For Sale/Trade 2 12-16-2007 09:31 PM
Hpi rs4, tamiya tt01, tamiya tg-10, tamiya sprint! MORE!!!!! Genuinekid R/C Items: For Sale/Trade 10 09-10-2007 04:21 PM
