Tamiya M04
#17
#18
ok, so i'll ask the obvious newbie question:
what is the difference between modding your m03 to RWD and an m04? handling differences?
#19
None of the bodies mentioned will fit an M04...too long. To use them and have the "drive" end where it prototypically belongs requires either using an obsolete (and somewhat hard to find) M02 chassis OR mod the M03. As was just discussed on the M03 thread, I would guess the RWD M03 will be somewhat more maneuverable/more suited to tighter tracks which ours tend to be. That said, other than screwing around with our club the modded car would probably not be accepted anywhere M-cars are formally raced as contrary to TCS rules it has been substantially "re-engineered".
#20
Hey are few pics of my M04!
My setup to date:
front short blue springs (tam# 53333), rear short red springs (tam# 53333)
front 1.5 degree toe out, rear 2.0 degree toe in
front 5mm ride height at lowest point, rear 7mm ride height at lowest point
front 6mm spacing in shock, rear 7mm spacing in shock
front 1.5mm droop, rear 0mm droop
coil overs spun all the up in front, 5mm down in the rear
front 40wt associated fluid, rear 30wt associated fluid, 3 hole pistons all the around
outside hole used on the rear shock tower
Tamiya 60d slicks with hard inserts
front 5mm hubs, rear 6mm hubs with 1.5mm of spacers
ball diff, full ball bearings
This is the setup some far, continual improving as the season progress!
My setup to date:
#22
In 2006 your correct, however I don't know that it had the fastest lap (think that honor may have gone an M03?) That winning M04 was very quick off the line and out of the corners...and was set up very well. He started near the front and was tough to catch with a clear track.
#23
Is the Eunos a M or L body?
#26
At the laurel md race last year they separate the m03's and m04's
#28
Last year the ran the M03's and M04's seperately because that was how the 2006 rules wwre set up. This year they run together. There will be a Laurel race on July 15th. Hobbyworks (the only original TCS race venue other than Aliso) had their trailer of race equipment stolen earlier this year but word is that they will be ready for their annual TCS event in July.
#29
Hobbytown Glen Burnie is loning their equipment and trailer with crew to set up and help with the race , also the night before their will be a TCS warm up race in Glen Burnie.
The reason that I was told They separated the classes was the gearing with the M04 upu can go a tooth higher than the M03.
#30
