Old 04-22-2003, 10:56 AM   #16
CGR
CGR's Avatar
BEst way to strip the anodizing is to have a shop do it. 2nd best is to bead blast it.
CGR is offline   Reply With Quote
Old 04-22-2003, 04:02 PM   #17
Racer X's Avatar
I've tried the oven cleaner thing and ended up with very pitted parts. In hindsight, I think I would have just gotten new parts or used the polishing wheel that I had to use to save the old parts to buff the anodizing off.
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 04-22-2003, 04:58 PM   #18
birdy233's Avatar
Trader Rating: 78 (100%+)
I have used it with great results on aluminum and Tamiya "hard" bodies paint removal. Heck even RCCA had articles on this same subject and they used easy off. I never had pitting problems, but I suppose it can happen??
birdy233 is offline   Reply With Quote
Old 01-08-2012, 04:33 PM   #19
bigbadbronx2k12's Avatar
Default De anodizing
Oven cleaner dosen't work that good. I have used Drano gel and let it sit for 3 hours. Result...beautiful de-anodized parts with zero pitting.
The undefeated Dragg Maxx
The "Preying" Mantis Truggy
Yokomo GT4 ST Bronx Edition
Deadman Racing....When you race a Deadman you tell no tales!
bigbadbronx2k12 is offline   Reply With Quote
Old 01-08-2012, 04:59 PM   #20
9-year old thread???
Serzoni is online now   Reply With Quote
Old 01-08-2012, 09:44 PM   #21
Default yep
I was searching the forum for a way to do it myself, found a good Youtube video, figured I'd share. Didn't see the post date. No big deal, lol.
Old 01-11-2012, 02:38 AM   #22
It doesn't matter how old the thread is if you're contributing to it.
jduarte is offline   Reply With Quote
Old 01-11-2012, 10:04 AM   #23
still a useful subject and it answered my questions. Thx guys
www.serpent.com
www.comedycomposite.com
http://www.rc-ride.co.jp/
Titanium is forever...?
Operator27 is offline   Reply With Quote
Old 01-11-2012, 11:46 AM   #24
Coelacanth's Avatar
Here's my procedure, documented in more detail with my current Turbo Optima build here. I didn't experience any pitting with any of the parts (with this build or my previous CYANide build) by doing this procedure.
http://www.rc10talk.com/viewtopic.php?f=30&t=21530
1. Spray Easy-Off Heavy Duty oven cleaner on your anodized parts, let them soak for a while in a plastic pail or something. It only takes 5 or 10 minutes before you'll see the anodize coloring coming right off. Don't breathe the nasty smell and don't get Easy-Off on your skin, it will begin to itch. Rubber gloves and ventilation are important.
2. Rinse off the parts in hot water and re-spray any areas that still have areas of anodizing. I use a toothbrush to help get into the nooks & crannies.
3. Once all the anodizing is gone, you'll see either a dull silver or a charcoal grey finish...I think it depends on the quality of the aluminum. Now you get to work with the polishing.
4. Polishing aluminum is the same as for any other material; you wet-sand with progressively finer grits until you achieve your desired level of glossiness. It ain't easy and you won't score any points by taking short-cuts. Start with 400-grit and wet-sand, then repeat with 600, 800, 1000 & perhaps even 1500-grit. Some parts, I stop at 1000, some at 1500. I don't go any further (rubbing & polishing compound) if I'm planning to have the parts re-anodized, but if I want a nice glossy almost-chrome-like finish, I'll do step 5.
5. Rub down the parts with automotive rubbing compound; 3M or Turtle Wax or whatever. I prefer the paste that comes in little tubs. Repeat that procedure with automotive polishing compound. Lastly, I'll repeat with Nu-Finish Scratch Doctor, which gets the parts very nice and shiny. Again, step 5 isn't really necessary if you're planning on re-anodizing the parts.
How do you de-anodize aluminum-de-anodizedparts1.jpg   How do you de-anodize aluminum-polishedparts1.jpg
"Paranoia roams where the shadows reign." ~Marillion
Coelacanth is offline   Reply With Quote
Old 01-11-2012, 01:18 PM   #25
cwoods34's Avatar
I basically did as posted above on my TC6 parts. I soaked them for 10-20 minutes in Easy-Off. MOST of it simply rinsed off.... there were a few spots where I had to gently rub the area with a shop rag (wet with Easy-Off). After that, I rinsed with hot water and dried the parts with a towel.
I did not do a sandpaper cycle.... although the parts came out looking nice, I now wish that I had done it!
Terry cloths and Mother's Aluminum Polish put a NIIICE shine on them
Stop holding bitterness deep in your bum soul.
cwoods34 is offline   Reply With Quote
Old 01-12-2012, 11:59 AM   #26
Thank youuuuuuu. Exactly.
Old 01-12-2012, 12:46 PM   #27
samnelso's Avatar
Just a couple of extracts from wiki:
"...the coating [Al anodizing] is susceptible to chemical dissolution in the presence of high and low pH chemistry, which results in stripping the coating and corrosion of the substrate."
and
"Because the dye is only superficial, the underlying oxide may continue to provide corrosion protection even if minor wear and scratches may break through the dyed layer."
Just a thought to consider if you need your "de-anodizing" method is removing just the color or the actual oxide.
Team Associated | Reedy | Airtronics
RC Excitement: Fitchburg, MA | RC Madness: Enfield, CT | Horsham RC
samnelso is offline   Reply With Quote
Old 01-12-2012, 01:50 PM   #28
Coelacanth's Avatar
and
I personally don't believe everything I read on Wikipedia. Here's a better forum topic on the matter:
http://www.finishing.com/2000-2199/2076.shtml
Sodium Hydroxide (NaOH) is a chemical that will remove anodizing, and is one of the components in Easy-Off HD Oven Cleaner:
http://www.rbnainfo.com/productpro/P...=PL&template=1
At any rate, it's possible to physically remove the layer of anodizing (sanding/bead-blasting) but since anodizing is extremely hard, you'll be spending a great deal of time & effort doing it. Either way, you're left with a rough surface that requires the aforementioned wet-sanding and/or polishing to re-prep the surface properly.
I'm fairly certain anodizing is more than just a layer of color; it's a chemical process that changes the outer surface of the aluminum while coloring it at the same time. I doubt you can strip the color while leaving the anodizing behind.
Old 01-12-2012, 02:27 PM   #29
samnelso's Avatar
Whatcha talking about? Wiki is spoken word written on the parchment of time.
NaOH...basic solution (high pH)
You are correct about anodizing being more than just a color, but it is not a color. The anodizing is the growth of the oxide. The color is a dye that fills in the oxide pores.
Old 06-01-2012, 02:57 PM   #30
hefe's Avatar
This thread helped me quite a bit..
I set up an anodizing station in my shop with some extra electro forming equipment. So far I just did a couple small items that were already anodized. First one I used grease lightning to remove the ano...worked amazing..but when I tried to re-dye it..it didn't work at all. Apparently the pores of the ano were still sealed..and the only way to redo the surface is by removing and polishing the piece.
In this case,,you don't need to bother with the oven cleaner since you will be polishing the coating off anyway..
And RiT dye works wonders for anodizing..
mp9 tki2 WC - Alpha Plus A852
mp9 mp9e tki2 - tekin rx8 / 1900kv
hefe is offline   Reply With Quote
Wanted: Anodize information Jason R/C Items: Wanted to Buy 3 12-01-2006 09:00 PM
Anyone does Anodize? FRP Nitro On-Road 2 04-19-2006 08:37 AM
All aluminum beautiful mini t for sale, GREAT car, aluminum chassis and everything!!! t to the maxx2 R/C Items: For Sale/Trade 10 12-12-2005 05:09 PM
removing anodize...... cfloyd Painting, Designs, Graphics and Photography 2 07-19-2005 12:25 AM
How to remove anodize from alu? keiseng79 Malaysian R/C Racers 25 05-24-2004 08:22 PM
