Old 06-09-2007, 09:17 AM   #1
Simon M's Avatar
Default muchmore power master
Just got a mm power master v2 24A today with a mm power station,
The power station has 5 outputs instructions say 3 of the outputs can only handle 10 amps so what can i hook up to the power board and to what outputs?
I have a CTX-Cell Master, Motor master V3.0c, CTX-D2 Discharger, Tire Truer and will be getting a comm lathe next week.
Serpent 960
Serpent 720
Serpent S400
Serpent S120
Tamiya M03-R
www.serpentradiocontrolcars.com.au
www.smaracing.org
Simon M is offline   Reply With Quote
Old 06-09-2007, 11:23 AM   #2
JayL's Avatar
cell master and motor master plug into the non switched plugs.
the ctx-d2 and the tire warmer plug into the switched plugs.
your lathe will connect to the motor master
JayL is offline   Reply With Quote
Old 06-09-2007, 05:29 PM   #3
Simon M's Avatar
Thanks Jay
Forgot the lathe runs off the motor master
Serpent 960
Serpent 720
Serpent S400
Serpent S120
Tamiya M03-R
www.smaracing.org
Old 06-09-2007, 10:54 PM   #4
Big B's Avatar
If you are only going to be running 1 charger that will work fine, if you ever plan to run 2 chargers, I would suggest picking up a Mini Power Master, that way you can run the CTX-D2 and Tire Warmers off the Mini and everything else off the 24amp PM.
Big B is offline   Reply With Quote
Old 06-09-2007, 11:01 PM   #5
Default Power
I have a CE power supply 23amp, and MM Power Station, I've ran everything from my ctx-c, ctx-m, ctx-dv2, motor cooler and automatic tire truer. I have never had a problem overloading the non-switched or switched terminals. I know it says 10amp max but I've run my tire truer off the switched terminals and had no problem. If you do overload it the only thing that burns out is the LED, the switch and circuitry can handle the amperage.
_pilot_ is offline   Reply With Quote
Old 06-09-2007, 11:14 PM   #6
hierog's Avatar
i would run the motor master off straight off of the ps. i ran mine through one of the non-switched ports and it ruined that port. MMR fixed it for me, but they told me to connect the motor master directly to the power supply from now on.
I run my CTX-D, CTX-C, and GFX to my switched ports and i've never had a problem.
I run my motor cooler directly to the power supply also
Better to be safe than sorry.
vic
hierog is offline   Reply With Quote
Old 06-10-2007, 02:17 AM   #7
GymBeam's Avatar
hi just asking if on the Power master if the Two red outputs are the same. ans the two black output are the same.
i.e in the pic below you could connect your Charger Red to R1 and Charger Black to B2.
also would it be better on the power master to split your two chargers between the two different outlets to distribute the load? or it doesnt matter?
GymBeam is offline   Reply With Quote
Old 06-10-2007, 02:22 AM   #8
Simon M's Avatar
I had mine hooked up that way for its first test run,
Seemed to go OK.
Serpent 960
Serpent 720
Serpent S400
Serpent S120
Tamiya M03-R
www.smaracing.org
Old 06-10-2007, 05:49 AM   #9
VooDooPH's Avatar
Trader Rating: 18 (100%+)
Send a message via Yahoo to VooDooPH
i'd run two powermasters if you'd be using all those stuff.
VooDooPH is offline   Reply With Quote
Old 06-10-2007, 08:46 PM   #10
more$thanbrains's Avatar
Send a message via MSN to more$thanbrains
their the same
just 2 outputs on one wire
i had mine open to add another fan
Xray~Titan~Ko Propo~Orion~Muchmore~Dekelz.com
T2 007 US/EU~CRC Gen-XL~MO3-Pro~NT1~Corally C10X
'73 Ford Bronco sittin on 36" swampers~ 10" lift
more$thanbrains is offline   Reply With Quote
Old 06-11-2007, 06:31 PM   #11
GymBeam's Avatar
more$thanbrains, how hard is it to add a fan? what sort of fan did you put in?
also what voltage setting people put on the Powermaster? Mine came standard with 12.4volts.
will putting higher voltage will mean the charger will have lower overall amp?
Old 06-11-2007, 08:25 PM   #12
mine didnt come with a fan in it
so instead of sending it in i just put one in myself
thats all
Old 06-11-2007, 08:35 PM   #13
Big B's Avatar
When did you get your Power Master? The new ones should all come with a fan, I wonder if it was the first Power Master?
Old 06-12-2007, 10:41 AM   #14
JayL's Avatar
My man hierog is right, except that his blue stuff is faster than mine , I do plug my motor master into the power supply direct as well...forgot since I've been running brushless lol
for the voltage: I got the manuals out for every item I wanted to plug in and found the voltage range for every item..once I had the highest voltage that the lowest item could take I used a volt meter and set my voltage just .1-.2 below that
Old 06-12-2007, 06:04 PM   #15
GymBeam's Avatar
i cant help but think its just a cheap computer power supply in nice packaging.
when i apply load to the power supply the voltage drops. whereas good ps's the voltage will be stable
however sure is a pretty power suuply.
WTB MUCHMORE POWER MASTER BLUE blade072 Australia Wanted to Buy 1 12-20-2007 06:16 AM
***WTB*** MuchMore Power Master Mini atomapapa R/C Items: Wanted to Buy 3 02-22-2007 12:12 AM
WTB MUCHMORE POWER MASTER BLACK gotyournumber R/C Items: Wanted to Buy 0 12-04-2006 12:59 AM
MUCHMORE Power Master 20A power supply Swampracer R/C Items: For Sale/Trade 5 09-15-2006 09:02 PM
WTB - Muchmore Power Master uniquexme R/C Items: Wanted to Buy 0 04-09-2006 05:56 AM
