Schumacher lower arm slop >
Old 06-07-2007, 06:35 PM
Default Schumacher lower arm slop
Hello,
Not sure if I'm posting in the correct section but i have tried searching with no luck!
Just wondering if there is meant to be 1mm slop on the front arms? The manual states that there should an o-ring (u1960), arm and washer (u2450) though the pivot pin. Should i find another washer to take up the slop?
I have a feeling is the arm moves it is going to put the car out of alignment.
Thanks!
psykosonik is offline
Old 06-07-2007, 06:50 PM
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
What Schumacher car are you talking about?
Jon Kerr is offline
Old 06-07-2007, 06:56 PM
sorry, im talking about the mission1
i have just upgraded to the pa titanium pivot pins...
Old 06-07-2007, 07:04 PM
justin lessard's Avatar
have the arm free but with no slop
justin lessard is offline
Old 06-07-2007, 07:17 PM
yeah i figured....
so I'll have to find some other shims to take up the slop or does part number u2450 come with 2 different sizes of plastic shims/washers?
Thanks for your help!
Old 06-07-2007, 08:02 PM
Originally Posted by psykosonik View Post
yeah i figured....
If you're in a crunch and need to reduce some slop you can always use a dab of super glue, let it dry and then reassemble.
Hope this helps
sf85 is offline
Old 06-07-2007, 08:12 PM
thought about that but i prefer to do it right the first time.
I have attached an image from the manual showing where and which direction the slop is coming from.
there is a gap allowing the arm to slide forwards and backwards by about 1mm marked in red dots
i have followed the manual accordingly. using the red rubber o rings and 2mmx1/8" spacer
Old 06-07-2007, 11:46 PM
Super Moderator
Marcos.J's Avatar
Trader Rating: 217 (100%+)
i had same problem on my R12( nitro car) i took the o ring off and replaced it with a plastic shim, end of slop
Marcos.J is offline
Old 06-08-2007, 01:15 AM
Speedie's Avatar
I took out the rubber o-rings on my Mission and just used some teflon shims to make up the difference. Workes well. I run mine on a dirt oval track.
Speedie is offline
