Wing Mounting
Old 06-07-2007, 03:12 PM
Default Wing Mounting
I am sure this has been posted somewhere else. However, I was looking at pictures from the Reedy Race and some from the last worlds in Italy. And the drivers had mounted the rear wing farther back, making the wing hang behind the rear or car instead of ontop of the rear of the car. You know what I am talking about?
I want to know what handling characteristics this gives the car?
Thanks in advance. Any information is helpful.
atxgman is offline
Old 06-07-2007, 03:18 PM
more rear traction
HEWITT is offline
Old 06-07-2007, 03:20 PM
Martin Hofer's Avatar
mounting the wing further back gives you much more rearendgrip whilst steering stays the same resulting in a much smoother driving car. once you tried you never go back. mounting the wing further forward is just a waste of grip, nothing else
Martin Hofer is offline
pepecueva's Avatar
Is there something in ROAR rules against this?, or is it 100% legal?
pepecueva is offline
Old 06-07-2007, 03:21 PM
thanks guys I really appreciate the info. I am going to go mount it up that way now.
atxgman is offline
Old 06-07-2007, 04:17 PM
Skiddins's Avatar
In the UK the following rules are for the body;
I don't know how far the wings hang over at the international races but there should be a diagram of body dimensions for ROAR somewhere.
Skiddins
Skiddins is offline
Old 06-07-2007, 07:05 PM
SWTour's Avatar
I did see a picture on ROAR's site, but this was the nuts
8.9.5.7 Body rules:
• Bodies must resemble 2 or 4 door cars that have raced in a Touring Car series. See
Global Body Specifications below.
• Wheel arch cut-outs: Maximum 9.5 mm over tire diameter
• The rear of the body may not be cut higher than 55mm above the measuring surface
with the chassis resting on 20mm blocks.
• No windows may be cut out.
8.9.5.8 Wing rules:
• Only one wing is allowed, fixed to the same place as the wing on the full-size vehicle.
• The wing must be fastened to the rear deck of the body, not directly to any part of the
chassis of the vehicle.
• The rear edge of the wing or side dams may not extend beyond the rear of the body
more than 10 mm.
• No part of the wing may extend above the roofline of the body.
8.9.5.9
SWTour is offline
Old 06-08-2007, 05:16 AM
Capelracer's Avatar
Same 10mm overhang rule in Australia
Capelracer is offline
Old 06-08-2007, 06:47 AM
Skiddins's Avatar
Looks like the BRCA picture applies to the ROAR rules, with regard to the wing at least.
Skiddins
Skiddins is offline
