Old 06-05-2007, 04:45 AM   #1
Default New Brushless Cooling - TCS
This is the new "Brushless Cooling System" from TCS
The new cooling plate fits onto the speedo.
Various plates are available for different speedos. This one is for Novak GTB, LRP Sphere, and Nosram
The results are amazing. In recent testing the following data was relayed by Spektrum Telemetry
Borden (UK) test - Brushless Motor.pdf
Borden (UK) test - Brushless ESC.pdf
The track and gearing was deliberately chosen to push our brushless motor and speedo to the limit. At 5minutes 20 seconds, the Motor and ESC without the TCS went into thermal cut out mode.
As you can see, once the TCS was fitted, the temperatures came right down and we even had the option to fit more power !
Filling the system
RWeatherley is offline   Reply With Quote
Old 06-05-2007, 04:48 AM   #2
What was the running weight of the chassis?
Dragonfire is offline   Reply With Quote
Old 06-05-2007, 05:08 AM   #3
Default TCS
A Complete TCS weighs 48g (approx 1.8oz)
The figures in the graphs are from a Predator, at off-road weight of 1590g.
The results from a touring car at 1500g are pretty much the same, but using a more powerful motor, a 4.5 instead of 6.5, to obtain similar temperatures.
Old 06-05-2007, 05:42 AM   #4
kufman's Avatar
Was temperature data taken after the car was stopped? I am trying to figure out why the end of the temp graphs dip back lower around 330 sec. Is this when the car was taken off the track?
kufman is offline   Reply With Quote
Old 06-05-2007, 05:57 AM   #5
Default Graphs
Yes the car was stopped at 5 minutes
The running temperature was taken every 30 seconds.
We used telemetry to obtain the data, so that the car could be run continuously for the whole run, without stopping it.
The telemetry enables you get real time information without affecting the results by having to stop the car and take temperatures.
Old 06-05-2007, 09:13 AM   #6
nagatahawk's Avatar
does the tcs cool both the esc and the brushless motor? or either or?
nagatahawk is offline   Reply With Quote
Old 06-05-2007, 09:31 AM   #7
Default TCS
Yes, there is a liquid cooled plate that goes between the motor and the mount, and a second cooling plate that goes on top of the speedo.
(please see images above)
Old 06-05-2007, 04:19 PM   #8
whats the point of the liquid? does it just sit inside the plates?
Tyler1 is offline   Reply With Quote
Old 06-05-2007, 06:18 PM   #9
chris moore's Avatar
Trader Rating: 88 (99%+)
Do you have a website link?
chris moore is offline   Reply With Quote
Old 06-05-2007, 07:28 PM   #10
no, do you have it?
Old 06-06-2007, 08:44 AM   #11
nagatahawk's Avatar
correct me if I am wrong, but the liquid is for cooling. This is achieved by cirulating the liquid from the motor/ esc plate to the radiator by a small pump.
wn
Old 06-07-2007, 11:39 AM   #12
Default TCS
A tiny micropump circulates a non-conductive liquid through the system. The fluid passes through a thin plate which is sandwiched between your motor and chassis where your motor's excess heat is extracted into the coolant. Forced by the pump the coolant continues to the cooling radiator which efficiently releases all of the excess heat, into the passing airstream.
On the Brushless TCS there is also a cooling plate which attaches to the speedo.
Old 06-07-2007, 12:24 PM   #13
Default TCS
The link is www.tcscooling.com
Old 06-09-2007, 09:15 AM   #14
Default TCS
wn
A typical TCS installation contains just 5ml of coolant (about a teaspoon). It is highly thermally conductive, but NOT electrically conductive.
The radiator is also very strong, you could throw it at the wall and it won't break.
Two different installations in a Tamiya :-
brushless motor cooling fan dragon breath Radio and Electronics 1 08-13-2008 04:08 PM
Brushless Motor Cooling Fans? azrael_nite Electric On-Road 3 04-29-2008 06:05 AM
FS: Brushless motor - Orion 5.5 w built in cooling fan! Hausuzo R/C Items: For Sale/Trade 0 02-01-2008 02:42 AM
Best cooling solution for 1/10th onroad brushless motor vazzo Australian Racing 13 01-13-2008 05:00 PM
cooling brushless motors? aus jd 2703 Electric On-Road 34 09-03-2007 09:46 PM
