Old 04-18-2003, 11:15 AM   #1
Registered User
Angry cutting front bumper foam
I have protoform dodge stratus 2.0 for my 414mII, and the bumper is too big for it. What and how to make good cutting on front bumper foam?
Aku-Man is offline   Reply With Quote
Old 04-18-2003, 11:17 AM   #2
i just use a rough grinding bit on my dremel, but rough sand paper works good too.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 04-18-2003, 11:18 AM   #3
Macky's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Macky Send a message via Yahoo to Macky
I use my dremel with the sanding attachment.
Macky is offline   Reply With Quote
Old 04-18-2003, 11:52 AM   #4
A sharp exacto knife worked for me when I cut a new bumper for my 1/12 this morning.
RC Paperboy is offline   Reply With Quote
Old 04-18-2003, 11:53 AM   #5
davioh's Avatar
Default Re: cutting front bumper foam
i hav the exact same problem with my evo 3....but it works...not VERY good but it works....hehe would the styre foam cutter from tamiya work? (one of those build it urself kits had it when i was little)
davioh is offline   Reply With Quote
Old 04-18-2003, 03:48 PM   #6
rtypec's Avatar
This is a damn good question? I've used very rough sand paper (40-80grit) but it takes for ever get nice round shapes. What dremel attachment do you guys use for your bumpers?
rtypec is offline   Reply With Quote
Old 04-18-2003, 05:11 PM   #7
Korey Harbke's Avatar
I just use a dremel with a rough grit sanding drum. It works good. I usually smooth the edges out with a firer grit sandpaper by hand though. Just get the rough shape you want with the dremel.
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-18-2003, 08:16 PM   #8
popsracer's Avatar
Default cutting front bumper foam
Guys;
I use a single edge Razor Blade for the rough trimming, then some 80-100 Grit Sandpaper (on a sanding block) for the smoothing. Looks almost Factory when your done.
popsracer is offline   Reply With Quote
Old 04-21-2003, 02:57 AM   #9
rough512's Avatar
Default Dremel
I used the dremel routing bit. I made myself a nice bumper from a soft rubber sandal. I used the routing bit at high speed to cut the rubber to form then used a dremel grinding stone to smoothen out the edges. I used the flat top of the drum instead of round side. I trimmed the corners to a bevel edge.
rough512 is offline   Reply With Quote
Old 04-21-2003, 03:10 AM   #10
davioh's Avatar
i used an exacto knife...it doesn't look like factory but it works
Old 04-21-2003, 10:43 PM   #11
Suspended
Yeah i just used a nife and it works.
R C king is offline   Reply With Quote
Old 04-22-2003, 10:06 PM   #12
rough512's Avatar
After 30 minutes of dremel work...
Old 04-22-2003, 10:27 PM   #13
Moderator
Speedo's Avatar
Looks really nice, too bad it wont stay like that
Speedo is offline   Reply With Quote
Re. WTB Red Foam Bumper kang45 R/C Items: Wanted to Buy 4 02-12-2008 10:48 PM
XRAY FKO4 FRONT FOAM BUMPER Hal O. R/C Items: Wanted to Buy 3 03-22-2007 08:55 PM
Cut Foam Bumper jaykay Nitro On-Road 9 12-15-2006 07:23 AM
Hard foam front bumper for XRAY T1FK'05 NOTFASTENOUGH R/C Items: Wanted to Buy 2 10-06-2006 12:15 PM
FS:New RPM Front Bumper LOOK Platinum_Racing R/C Items: For Sale/Trade 3 03-25-2006 04:43 PM
