1/12 Calandra
Old 06-02-2007, 06:40 PM
Default 1/12 Calandra
uhm can you please help me and tell me what i need to make this car run. with a link to the the parts.asap
Carpetracer92 is offline
Old 06-02-2007, 07:19 PM
Well obviously you'll need a servo and servo mounts. Other then that you need the battery capstans and the o-ring that holds the battery in place. The top plate on the rear pod looks like it's from a different car which is why there's no damper plates or tubes on the car so you'll need a new top plate, damper tubes and ball studs for the damper tubes. You may or may not want to change to the Dynamic Strut front end...the one you have will work to get you started though.
InspGadgt is offline
Old 06-02-2007, 10:17 PM
12thScaleCrazy's Avatar
"You may or may not want to change to the Dynamic Strut front end...the one you have will work to get you started though."
....The old style front end just won all the ROAR 12th titles at the Nats didn't it?
12thScaleCrazy is offline
Old 06-02-2007, 10:25 PM
HOW MCUH DO YOU THINK IT WILL COST I GOT A SERVO ALREADY
Old 06-02-2007, 10:38 PM
Default 1/12
Shouldn't be more that $80-$100, servo mounts, battery o-ring and o-ring standoffs, upper pod plate and damper tubes, after that throw a body on it and your ready to go...oh and if you can update that front end. I would also get rid of the deans connectors and hardwire the battery in, it will save some space. You can also change the wire to a smaller gauge, you don't need the big stuff in 1/12.
_pilot_ is offline
Old 06-02-2007, 10:40 PM
I don't know...I didn't see the results. Then there's also races won with the Dynamic front end as well. It all depends on what your preference is and what works best at the track your running on.
Old 06-03-2007, 06:28 AM
squarehead's Avatar
Trader Rating: 75 (100%+)
Looks like a CRC Carpet Knife 3.1, and for starters, as previously mentioned it needs the proper battery retention system (the cardboard won't cut it) and dampner tubes with ball link mounts. It also looks like it has some odd plastic "toy car" shock on it that seems to be almost fully compressed, too. A CRC DuraShock would be a nice addition. Looks like it needs a body, also.
It seems to have been put together from junk parts that someone had lying around. Good electronics in it, though. I hope you didn't pay TOO much for it, because it needs quite a bit.
Drop by the guys at www.teamcrc.com to get all of the parts that you need. They have great customer service and should be able to get you on the track with minimal strain.
Good luck.
squarehead is offline
Old 06-03-2007, 07:11 AM
wallyedmonds's Avatar
you need to get a gen x
joking
wallyedmonds is offline
Old 06-03-2007, 07:53 AM
WITH MY ELECTRONICS THE CAR COST 300 HUNDRED.
Old 06-03-2007, 08:03 AM
THINKS YOUR HELP BUT CHECK THIS OUT I MADE IT NEATER.
AND HERES THE NAD BODY.
Old 06-03-2007, 09:32 PM
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
all those are your electronics.? and the roller cost you 300???
chewiefttc4 is offline
Old 06-03-2007, 09:58 PM
Big B's Avatar
If you check around you can find a nice servo for that on the sale thread, or post in the WTB section. I would either rewire that esc or get some heatshrink for the solder joints. Electrical tape is ok but it can come off very easy, especially power wires cause they get warm.
Big B is offline
