Old 03-13-2008, 10:34 AM   #541
Shawn Palmer's Avatar
What was the pack voltage before putting it on the charger?
Anything below 6.0v and damage has occurred. The lower the voltage, the more damage.
Shawn Palmer
Speed Passion USA Sales Manager
USAsupport <at> King-Golden <dot> com
www.SpeedPassion.net
www.SpeedPowerrc.com
Shawn Palmer is offline   Reply With Quote
Old 03-13-2008, 10:39 AM   #542
stitchy's Avatar
You know, I was in such a panic, I didn't check. Plus I figured by the time I got the battery on the charger to look at the voltmeter, it would have sorta "recovered" and any reading would be misleading...
Is there any other way I could find out if it's been damaged? Will it just not perform as well, or have different charging characteristics?
stitchy is offline   Reply With Quote
Old 03-13-2008, 11:35 AM   #543
Depending on the depth of the overdischarge, best case scenario is you've just reduced the cycle life of the pack, with little or no performance degredation.
Worst case would be an immediately recognizable drop in performance the next time you run it. If this turns out to be the case, I would then be extremely cautious of the pack each and every time it's on the charger, and watch for any signs of puffing. It will also show far fewer mah capacity than before (both in runtime, and on the charger).
Shawn Palmer
Old 03-15-2008, 11:26 PM   #544
when willl the udc 20's be back in stock
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 03-16-2008, 11:53 PM   #545
stitchy's Avatar
Is the Core 6 amp power supply enough to power the UDC-20? I know it only charges at 5 amps, but I've heard some chargers need more than their output implies...
If not, how many amps does the manual specify is needed? Thanks
Old 03-17-2008, 07:59 AM   #546
Both CORE chargers in stock!
We've been using the CORE 6A power supplies w/the CORE chargers at full loads for quite a while with absolutely no probs!
Shawn Palmer
Old 03-17-2008, 03:01 PM   #547
http://www.racing-cars.com/usa/searc...&templateid=12
it says all outta stock?
i wanna order a charger sp gt core 5000mah sp 5.5 drive shaft pins revlite wheels and pdub bumper and it wont let me
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 03-17-2008, 03:04 PM   #548
abailey21's Avatar
Trader Rating: 36 (100%+)
Email me the order!
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 03-17-2008, 03:21 PM   #549
all sorted sorry bout that should just called to start with.
cheers
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
Old 03-28-2008, 06:09 PM   #550
I'm using the core UDC-20 charger and love it so far. Just one question - What's up with the fan on the left side of the charger? My charger gets pretty warm and the fan never kicks on. There are also two different plugs on the left side of the charger that the instructions don't explain at all. What's up with that?
I guess that's two questions.
EVILGRAFX is offline   Reply With Quote
Old 03-28-2008, 06:48 PM   #551
abailey21's Avatar
So yeah i've been seeing a lot of fan questions lately
Try charging a 3S LiPo, the fan will kick right on, on 2S and NiMh the charger doesn't get hot enough to warranty the use of the fan.
second question, there are 2 different power outlets on the side of the charger, one is built in (obviously its the one with alligator clips)
and the second one would be plugged into the socket, which give you 2 choices in plugging into your power source.
K.C.C.O.
Old 03-28-2008, 07:24 PM   #552
Thanks for the answers. There is also a plug on the left-hand side that has three prongs in it, kind of the size that a servo plug would fit in. Do you know what that is for?
Thanks again.
Old 03-28-2008, 10:33 PM   #553
abailey21's Avatar
If I remember correctly, software updates... but don't quote me on that!
Thanks again.
K.C.C.O.
Old 03-29-2008, 07:48 AM   #554
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
dont worry we learn not to quote you on anything!
j/k see you tomorow
Old 03-29-2008, 08:01 AM   #555
abailey21's Avatar
lol, I really don't remember, Shawn told me once but I forgot..
j/k see you tomorrow
K.C.C.O.
SMC Lipos 7.4 5000mah wfdfiremedic Electric On-Road 624 08-27-2008 10:09 AM
CORE 5000MAH LIPO FOR SALE jsfrcfrk R/C Items: For Sale/Trade 5 08-05-2008 11:09 AM
Core R/C 5000mah 2s 7.4volt LiPo SchuMi2 Australia For Sale/Trade 2 06-08-2008 04:24 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
Core RC 5000mah Hard Cased LiPo - Brand New!! XACDesigns R/C Items: For Sale/Trade 8 01-08-2008 11:25 AM
