Old 12-23-2007, 08:35 PM   #286
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by Goingfast View Post
Question:
My understanding that all the 5000 lipo two cell are made by under the same company? PS not speaking 4 cell lipos.
Reason for question was .I've being told the all 2 cells 5000 lipo batteries are the same...
JayBee is offline   Reply With Quote
Old 12-23-2007, 09:38 PM   #287
C_O_jones's Avatar
Originally Posted by AdrianM View Post
OK, if you do not get the Core just be sure to buy Orion, FlightPower(TrackPower) or Apogee packs....everything else is not on par with the cells used in the above backs. Orion uses Kokam cells and Core, TrackPower and Apogee use the other good brand
Posted 7-24-2007
Bacon is Meat Candy
C_O_jones is offline   Reply With Quote
Old 12-23-2007, 09:50 PM   #288
JayBee's Avatar
Originally Posted by C_O_jones View Post
Posted 7-24-2007
Thanks for posting that Fred
I remember reading that somewhere
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
Old 12-23-2007, 11:18 PM   #289
heavy's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Born2Run View Post
Anybody knows where i can find these combo bullet connectors ?
Schumacher UK have them.
Honorary Life Member Logan RCCC -Mi6EVO and Serpent F1
Honorary Life Member Chargers RCCC -Cat K1 Aero
Life Member Bayside RCCC -Schumacher Mi6EVO
Boondall. SuperShot, XX, SVR,Schumacher Storm BigWig
heavy is offline   Reply With Quote
Old 12-24-2007, 12:52 AM   #290
Goingfast's Avatar
Trader Rating: 29 (100%+)
Posted 7-24-2007
Thanks Fred...
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 12-24-2007, 02:23 AM   #291
Goingfast's Avatar
Originally Posted by JayBee View Post
Hi JB
I found what i needed to know....
Old 12-24-2007, 05:31 AM   #292
abailey21's Avatar
Trader Rating: 36 (100%+)
I dont think I read anywhere in that post that "all packs come from the same place" Even though Adrian does bring up a good point
Posted 7-24-2007
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 12-24-2007, 09:34 AM   #293
C_O_jones's Avatar
Hi Adam, we had a discussion at our local track, SIR about lipos and I have been reading up on them, came across Adrian's post earlier.
The TrackPower 4900 will fit under the top deck of my Xray 007 where the Core 5000 is just a hair to tall to clear.
From his post, it seems the cells are both made by the same co.
Fred
Bacon is Meat Candy
Old 12-24-2007, 11:51 AM   #294
AdrianM's Avatar
Fred
The Track Power 4900 uses a diffrent cell from the Core 5000.
Adrian Martinez
Old 12-24-2007, 11:57 AM   #295
C_O_jones's Avatar
Thanks for clearing that up Adrian.
Bacon is Meat Candy
Old 12-27-2007, 10:07 PM   #296
slakr's Avatar
Currently I have 5 LiPo's (soon to be 6)
(2) Orion 3200
(2) Trakpower 4900
(1) CORE 5000 (just ordered a second one today)
I have been runing the 2 Orion packs for over a year in my T2R. I run the Trakpower packs in my AE T4 and the CORE pack in my Academy SVB2, but have only been runing these for about a month. So far, I haven't had a problem with ANY of these packs. I use a Scorpion balancing charger from FMA Direct and charge at 1C.
Some people I race with are reporting terrible cell imbalance issues with MaxAmps saddle packs (mostly used in AE B44).
Is this due to the cell configuration and/or quality of the cells?
Or is it that the balancing and 1C charging is really a necessity with LiPo's?
I have also noticed a lot of user error reported with LiPo cell damage/failure. This is one reason the charger I use is LiPo only, so I can't make a mistake with the wrong mode setting. I already had a Duratrax ICE charger, but I purchased an additional charger specifically dedicated to LiPo. Also, my Novak ESC's (GTB & XBR) not only have the LiPo cutoff enabled, I have never ran any of my packs down to the point that the cutoff kicks in.
Anyway, just some questions, observations and comments.
slakr is offline   Reply With Quote
Old 12-28-2007, 06:49 PM   #297
AdrianM's Avatar
Max Amps batts are not very popular in the R/C plane and Heli market. They tend not to last as long as other batteries. Their saddle packs are 2s2p and if the are getting imbalanced I bet the packs are not very well matched. You need some pretty sophisticated equipment to match Lipos...really only the factory can do it well. This is what Orion never has a probelm with the 4800's... they are 2s2p but they are matched by Kokam from the git-go. Max Amps assembles their packs here in the US.
Adrian Martinez
Old 12-29-2007, 01:22 AM   #298
syndr0me's Avatar
Trader Rating: 32 (100%+)
Even though I'm wary of the cells used in this pack, I decided to pick one up since it seemed to be the best option for the 416 with its connectors coming out one side. I had to remove the balancing plug so it didn't short out on the top deck, so I guess I forfeited my warranty. Anyway, so far, the pack has been great, punchy, and flawless. I'll probably go ahead and buy a second one for the convenience.
Is there any hope that the balancing connector will be made internal, or moved to a place where two opposing corners of the pack (long ways) aren't obstructed? It seems like that would work well in most touring cars, though I guess topdeck design varies quite a bit between them.
I'm using the nexusracing.net lead strips shoo goo'd to the bottom of the case to lock the battery into place. I've had a lot of trouble with flat sided batteries sliding around in the past. This solution has worked VERY well so far. I can't say I feel at all slower using LiPo than I did with NiMH using a 13.5, though maybe having my car exactly at minimum weight helps with that.
syndr0me is offline   Reply With Quote
Old 01-07-2008, 07:29 PM   #299
skypilot's Avatar
Trader Rating: 14 (100%+)
so after a few weeks of running without balancing i decided to stick it on the balancer, about 3 mintues later i took it off, lights came on, blinked a few times and was done.
skypilot is offline   Reply With Quote
Old 01-07-2008, 07:42 PM   #300
Trader Rating: 37 (100%+)
I don't know a ton about Lipos but I can say these Core 5000s perform just as good if not better then any other out there. I have run my car with EPs IBs and the Core. Without adding weight the car is ridiculous in the infield. But a little handful. Once I actually added weight the car was smoother and more balanced.
laptimes have not suffered either
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
SMC Lipos 7.4 5000mah wfdfiremedic Electric On-Road 624 08-27-2008 10:09 AM
CORE 5000MAH LIPO FOR SALE jsfrcfrk R/C Items: For Sale/Trade 5 08-05-2008 11:09 AM
Core R/C 5000mah 2s 7.4volt LiPo SchuMi2 Australia For Sale/Trade 2 06-08-2008 04:24 AM
New SMC Lipos 7.4v 2s 4000 and 5000mah HardCase IOwNMkeG R/C Items: For Sale/Trade 4 03-30-2008 01:54 PM
Core RC 5000mah Hard Cased LiPo - Brand New!! XACDesigns R/C Items: For Sale/Trade 8 01-08-2008 11:25 AM
